Go to Post With CD down... I wasn't sure what to do with my free time. I almost had a reality check and thought I might go outside. - Barry Bonzack [more]
Unread 02-29-2016, 02:46 PM
Dival Dival is offline
AKA: Yarden
FRC #3316 (D-Bug)
Team Role: CAD
Rookie Year: 2013
Dival is an unknown quantity at this point
Anderson PowerPole for 18AWG cables
We've noticed a strange malfunction concerning anderson powerpole connectors that we bought via AndyMark. When we used the connectors on 18AWG cables the contacts seemed to crimp well, but when we connected two powerpoles together the connection was unstable i.e. the housings fit together well but the contacts inside did not. From our experiance this happens only with 18AWG cables (the contacts crimped on 16,14 and 12AWG cables worked well). The problem might have been caused by using the wrong port of the crimping tool but we're pretty sure most of the cables were crimped right. We are aware that the specific contacts supplied by AndyMark are supposed to be suitable for 10-16AWG cables but they looked ok after we crimped them.
Has anyone else seen this kind of problem and knows how to deal with it?
Link to the connectors we bought:
http://www.andymark.com/product-p/am-2198.htm
2014 Israel Regional Winners! (Special thanks for team #1574 - Miscar and team #3065 - Jatt)
To come up with a complex solution to a complex problem is hard; to come up with a simple solution to a complex problem is even harder; but we both know what makes more fun.
Unread 02-29-2016, 02:49 PM
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: Anderson PowerPole for 18AWG cables
Noticed the same issue with some AndyMark branded PowerPoles I bought from MicroCenter on clearance.
Fixed it by removing the pin from the plastic housing, bending such that it would ride higher in the plastic housing and engage the opposite side harder and by bending up the little piece of metal (is it spring steel?) in the bottom of the plastic housing.
Worked fine for me after.
Unread 02-29-2016, 02:51 PM
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Those are PP45 crimps, meant for 10 gage wire. For 16 and 18 gage, you need the PP15 crimps. The housing is the same.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 02-29-2016, 03:14 PM
RoboTigers1796 RoboTigers1796 is online now
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
http://www.powerwerx.com/anderson-po...ings-contacts/
Here is the link for the PP15 terminals Knufire mentioned.
As he stated regardless how you crimp them you will not get a good crimp on your smaller gauge wire with the PP45's.
We stock PP15 for 16&18awg PP30 for our 12 gauge and PP45 for our 10gauge (usually only for drive motors or other very high current motors.)
You can see them all here
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 03-01-2016, 07:32 AM
Zagar's Avatar
Zagar Zagar is offline
Electrical Mentor 1506 Metal Muscle
AKA: "Always waiting for Electrical..."
FRC #1506 (Metal Muscle)
Team Role: Electrical
Rookie Year: 2015
Zagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of light
We ran into the same issue with all of the new internal lugs we bought this year. We wound up removing all of the lugs from the casings and very slightly bending the ends up to make better contact just like techhellpbb said. Worked great after that. Also are using the XT60 connectors, and those are amazing. No issues of connectivity there.
http://www.buddyrc.com/xt60-4-pairs-blue.html
