Go to Post You will forever be confronted with choosing between right and wrong, or choosing what you think you can get away with. Which way you go defines what kind of person you are. Choose wisely. - Gary Dillard [more]
Unread 29-02-2016, 18:25
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Team 423 Presents
For the first time, The Simple Machines has made a reveal video!
You can find it at https://youtu.be/2jb6QCIrkJo.
Here's some specs for our robot (copied from our website):
​~80 lbs, 14" tall
Drive & Chassis:
Custom-built chassis out of riveted 1x1" and 1x2" square tubing
Drivetrain sides attached to chassis by 2 bolts for easy maintenance
6x 8" VexPro wheels or 4x 10" pneumatic wheels and 2x 6" pneumatic wheels
4 CIMs @ 7.75 or 9.67 ft/s
Can cross category B, D, and low bar defenses with only drivetrain
Electronics mounted on vertical panels for easy access
Arm:
Roller @ end made from 8 VersaWheels, geared to 2.2 rps w/ 1 CIM
Polycord running along arm to intake boulders
Arm actuated by 1 miniCIM @ 450:1 reduction through worm gearbox
Strong enough to lift front of chassis to help with crossing defenses
Can be used to cross category A defenses
Climber: on the way
Defensive Wall: on the way
Sensors:
Potentiometer and limit switches for arm position
Encoder for roller speed
Limit switch to automatically stop intake
Camera for driving, picking up balls, and targeting low goal
Gyroscope, accelerometer, and drive encoders
HOW CAN WE HELP YOUR ALLIANCE?
Low goal cycler​
Can cross both defenses in 4/5 categories
Can play effective defense using defensive wall (not shown in video)
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
