Go to Post Thanks to everyone who made the regional possible - I know my team had a blast and I'm pretty sure most other teams did too. - Steve Howland [more]
Unread 01-03-2016, 09:52
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
Team Role: Leadership
Rookie Year: 2014
C.Lesco will become famous soon enough
Snowblower Motor driveshaft
So we bought the snowblower motor from andymark but didn't buy the sprocket we needed since at the time we didn't know it was a unique axle design nor did we know we would need a sprocket in the future. With the current canadian exchange and shipping it would take 100$ to order a small sprocket with the 10mm DD bore junk for an axle slot. Does anybody know of any cheaper and reliable sources for something like this? (25 series sprocket)
Unread 01-03-2016, 10:21
bernieseaholm bernieseaholm is offline
FRC #2960 (automation nation)
Team Role: Teacher
bernieseaholm is an unknown quantity at this point
Re: Snowblower Motor driveshaft
if it's a hubbed sprocket, can you drill out diameter to size of snowblower shaft, and then tap a set screw in side of hub to connect to snowblower shaft. good luck.
Unread 01-03-2016, 10:36
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Depends on what machining capability you have access to, and what other sprockets you have in hand.
If you have some 1/2 hex sprockets-
1) Best bet would be to water-jet a DD Hex insert
2) Mill a DD insert in Hex Shaft Stock.
3) Not the best fit, but you could also try just a 10mm center hole in a lathe. And then use preferably two set screw against the two flats.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 01-03-2016, 10:49
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
A good machinist with a milling machine could make easy work of modifying a hub to DD
