Go to Post So NASA is planning on blasting NERD deep into space? - Joe Matt [more]
Go Back   Chief Delphi > Other > Math and Science
  #16   Spotlight this post!
Unread 15-03-2016, 20:49
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
Rookie Year: 2013
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Re: Physics Quiz 12
Originally Posted by Ether View Post
... and the force on the D roller is downward (perpendicular to the rail)
Double-check that 632N number.
Whoops, thanks for clarifying the direction. Of course the force can only be down on the roller...
But I can't find the issue with 632N. The left over torque is -948 N*m and the torque arm from A to D is 1.5 m. no?
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
  #17   Spotlight this post!
Unread 15-03-2016, 21:32
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Physics Quiz 12
Where did you get this from:
the torque arm for the tension is 1.0 meter, which is found by extending the force vector backwards until a perpendicular line crosses through point A.
  #18   Spotlight this post!
Unread 15-03-2016, 22:27
mastachyra's Avatar
Rookie Year: 2013
Re: Physics Quiz 12
http://i.imgur.com/IU70nhu.jpg?1
OK, I see the error of my ways. I started from scratch (instead of trusting previous answers) and cleaned up my work to make deciphering a bit easier. I didn't bother with significant figures. New answer:
Part a) Tension on cable is 5454 N.
Part b) Force is 16082 N up on roller A and 291 N down on roller D.
I hope this is correct... mostly so we can get a new problem to work on!
  #19   Spotlight this post!
Unread 15-03-2016, 22:43
mastachyra's Avatar
Rookie Year: 2013
Re: Physics Quiz 12
Oh, you switched your question on me. I did things differently in my new answer, using the components instead of the actual tension on the cable. The 1.0 m torque arm was derived with the geometry that is circled and labeled TENSION TORQUE ARM. It's pretty crude, but I think it checks out. Here's clearer work on that part:
http://i.imgur.com/RCNAGre.jpg?1
  #20   Spotlight this post!
Unread 15-03-2016, 22:46
mastachyra's Avatar
Rookie Year: 2013
Re: Physics Quiz 12
and i just caught the mistake in that too... the 8 degree angle should be 12. Which makes the 36 degree angle 40, and the torque arm, x = 1.1 m.
  #21   Spotlight this post!
Unread 15-03-2016, 23:08
Ether's Avatar
Rookie Year: 1969
Re: Physics Quiz 12
Close enough. See attachment.
