Go to Post [on practice robots:] Twice the work and twice the practice building seem to equal twice the experience so far. - MrBasse [more]
Unread 02-03-2016, 17:06
Team 5706 Team 5706 is offline
FRC #5706
Team 5706 is an unknown quantity at this point
Motors?
We have set our motors up for our launcher and they are not running at the same speed they were when connected directly through the battery when running through the motor controller, even when we replaced the battery. Is a power drop common when running through a motor controller?
Unread 02-03-2016, 17:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Motors?
While they will never be perfect, they should be close, provided that the two motor controllers are of the same type, and (if controlled by PWM) calibrated. Don't necessarily expect (for example) a Talon SRX and a Spark to have the same voltage drop. Calibration is pretty easy; the directions are different for each controller type, but they're in all the user manuals.
Unread 02-03-2016, 17:36
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Are you using a encoder or something to measure the rpm of the motors or shooter wheels?
Unread 02-03-2016, 20:18
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Motors?
Yes, there will be a small voltage drop across the motor controller. CTRE has posted test data on their website.
