Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 02-03-2016, 19:08
anusha2617's Avatar
anusha2617 anusha2617 is offline
FRC #0178
anusha2617 is an unknown quantity at this point
FRC Driver Station: No Robot Code
Every time we compile our code from Eclipse while connected to a RoboRio, it says "Build Successful." But when we open up the Driver Station to Enable the code, it gives us a warning that we don't have robot code.
Name:	Build Successful.png
ID:	20253  Click image for larger version
Name:	No Robot Code.png
Unread 02-03-2016, 20:10
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: FRC Driver Station: No Robot Code
You're probably erroring out. You can check this by hitting the gear above the ds console and clicking "prints" than redeploying code
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 28-03-2016, 16:19
ARaine ARaine is offline
FRC #2834
ARaine is an unknown quantity at this point
If there is no error message just reboot the roboRIO. Sometimes the robot code does not start even though the code should run fine. I found this when I made one minor change (hardly code breaking) and the code did not start or provide an error message.
