Go to Post Computers have a nasty habit of doing exactly what you tell them to do instead of what you want them to do. - KenWittlief [more]
Unread 03-03-2016, 18:07
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Legal servos
So after reading the rules for this year it would appear that there isn't a power limit on servos. Specifically that vex servos would be legal. Am I missing anything?
Unread 03-03-2016, 18:24
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Legal servos
There is no "power" limit as such. But the "roboRIO is limited to a max current output of 2.2A on the 6V rail (12.4W of electrical input power). Teams should make sure that their total servo power usage remains below this limit at
all times."
So there is a max power output of 12.4 watts that will be your limiting factor
Unlimited PWM COT's servos are allowed, so there should not be a problem with the 3-wire VEX servo
Unread 20-04-2016, 21:41
SamM SamM is offline
FRC #5842 (Royal Robotics)
Team Role: Teacher
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Re: Legal servos
As a followup, what happens if you do try to draw more than 2.2A from the 6V rail?
We have some larger servos that we would like to use for their robustness, but don't have a max current listed. Will the RIO brown-out or be damaged if we try to draw more than the limit, or will the servos simply stop working correctly?
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 20-04-2016, 21:44
pilleya's Avatar
Elec+Mech
Rookie Year: 2013
Re: Legal servos
The servo can only draw as much current as the 12v to 6v converter can provide, the rail will not give out more than 2.2A.
Using a larger servo for the robustness is a great idea, it won't be able to draw more than 2.2 amps. The servo will still work fine, but will still operate at 13.2 watts. Nothing will happen to the robo-rio.
Facebook
