Removal of Low Bar Fabric
Today at the Greater Toronto Central Regional, the Field Stewards elected to remove the fabric and lower pipe from the Low Bar defense, keeping the upper frame of it on the field. They seemed to remove it after all of the flaps became too damaged for match play.
Thoughts? -Nick |
Re: Removal of Low Bar Fabric
Were there problems with boulders going through the low bar? How was this dealt with?
They said it would be a penalty if the teams strategically tried to roll a boulder under the low bar from the HP station. If it was not intentional, play will continue.
Can't change the field and then add a rule that doesn't exist.
They appear to be trying to do just that. I was just quoting what they said on the webcast a few minutes ago.
I want to see a team request a match they lose to be replayed citing the field did not meet specs. ![]() |
I think 1/16" thick polycarbonate sheet hanging from the Low Bar may better satisfy the design criteria for the fabric than the fabric does.
Hanging from rings?
Not sure what the fix is, but polycarb sheet isn't it. Maybe flaps/ vertical strips of plastic like you see on commercial freezer doors to allow entrance and egress, That would let the robot pass but stop the boulders. The strips would stay attached. They would need to run tests on entanglement. |
#10
Personally, I'd like to see a beaded curtain so robots can recreate the Britney Spears Oops!... I Did it Again artwork, but I would settle for plastic strips. ���� |
#11
I have been watching the event for the majority of the day, and I've seen, on several instances, boulders and the low bar interact in such a way that provides concerning circumstances.
1. Robots driving onto boulders, under the low bar. It can cause a bit of a jam, as well as damage to the robot if they are going to fast. 2. Boulders rolling through. The human player station aligns with the low bar, and with a normal toss, the ball can easily get onto the outerworks, or even past it. I'm curious to see how they deal with this, as not only does this raise scores by, in some occasions, having easier access to boulders, it also makes penalties in regards to boulders going over quite questionable. |
#12
The Granite State event just adopted the same field update.
#13
Designs like this, that have low forward facing surface area and contact the fabric above the pipe, are much more likely to rip the low bar fabric and trigger a G12 violation.
#14
And the robots weren't getting dinged on G12, or was it a problem that rounding corners can't fix?
#15
We built sidewalls on our robot, depending on the pipe, speed of transit, and the nap of the fabric to keep the flap out of our internals. Beads or strips would behave MUCH differently. We'd probably survive with the plastic strips, but our canopy design would have been much different with beads or strips than with the single flap. I have seen plenty of robot photos posted with similar flap/portcullis deflectors.
