Go to Post Your entire life is a choice - a choice to believe or denounce everything that is ever said to you. - Amanda Morrison [more]
Unread 05-03-2016, 10:25
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
How to easily find customized "standard" VI's?
In order to get 2 cameras working in labview this year, we had to modify several standard VIs. We tried to make sure that each time we edited a library or standard VI, we saved it with a new name in our project structure. However, we missed one or more.
Currently, our robot code and dashboard code can be built and run from any computer, but two cameras only works when the robot code is built, the dashboard is built, and the dashboard is run on one single laptop. We expect we modified a WPI or NI VI at some point on that laptop to get the two cameras working and then did not save the modified VI with a new name in our project.
We are manually going through the code now, but is there a way to get labview to give us some indication of the affected VI?
