Go to Post FIRST is not a party. It is the most important activity a high school age student can do. - JohnBoucher [more]
Unread 05-03-2016, 15:53
Republican31 Republican31 is offline
FRC #4057
Republican31 is an unknown quantity at this point
SmartDashboard crashes when set to C++
Hello!
I am trying to use the SmartDashboard for C++, but whenever I set it to any option in the driverstation, besides default, it closes and doesn't come up again. Even if I try restarting the driverstation, and the whole computer. It comes up again if I set it to default, but I can't use any C++ functions.
It has this problem on another team member's laptop too, but works on a different one. I've searched this forum and Google and haven't found a solution. Any ideas?
Unread 06-03-2016, 23:23
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: SmartDashboard crashes when set to C++
Go to C:/users/<insert your user here>/wpilib/tools
Shift right click and select "Open Command Window here"
Run the C++ dashboard with the command: java -jar smartdashboard.jar
Post the output here. It might give you a useful stack trace.
