Go to Post If we succeed, we succeed as a team if we fail, we fail as a team but either way, we are a team - we go home together and celebrate our accomplishments, whatever they are and try to learn from our mistakes. - KenWittlief [more]
Unread 05-03-2016, 21:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Open Flame in the Pits
Butane powered soldering irons are also good. They usually have a hot knife bit and a hot air bit that gets melting things hot. They get around the open flame rule since they're run off a catalyst once they heat up.
As for the rule itself, I don't think there's any other power tool a team could currently use that could actually being down an entire event. Not without serious misuse. A propane torch pointed the wrong way could quickly shut the entire event down.
Unread 05-03-2016, 21:33
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
We've recently discovered this works great for polycord: http://www.amazon.com/858D-Station-S.../dp/B009PPRJHS
I happened to have one and brought it in. You might try it on cord or rope. But if you do get one, I HIGHLY recommend making a modification for safety's sake. They wired the neutral wire to the fuse rather than the hot, so even if your fuse blows, you still have 110V running through your unit.
