Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Unread 06-03-2016, 14:02
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
Rookie Year: 2012
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Exclamation [Help!] Analog readings go crazy!
Hey everyone,
This year our robot uses 2 potentiometers and today after a defense cross both of them started jumping between readings like crazy with no pattern.
We had this problem before and the last time it happened because of a badly connected micro-switch which caused this problem when it was pressed.
This time we have disconnected all of the DIOs but it didn't help.
We tested the potentiometers' resistance and they work just fine...
We compete tomorrow and we worry that the same problem might occur on our competition robot.
What may cause it? Please help us.
Thank you.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 06-03-2016, 14:27
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: [Help!] Analog readings go crazy!
Sounds like a poor electrical connection. I'd check if your connectors are seated properly, connectors crimped properly and if there are any breaks in the wire.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 06-03-2016, 15:52
GuyM142's Avatar
AKA: Guy
Rookie Year: 2012
We checked and the readings actually jump from 0 to 1 (minimum to maximum) and even if the potentiometers aren't connected.
Any idea what it is?
Unread 06-03-2016, 16:56
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
The status of the AIO port is undefined when nothing is connected. You need a connection to pull the port to a steady voltage.
Post a wiring diagram.
Unread 06-03-2016, 18:27
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Rookie Year: 2012
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
You could have a short on one of your analog devices. We had this problem and traced it to some bad soldering and insulation by one of the students on one of our potentiometers. The black and red wires were touching underneath a big glob of electrical tape.
Check all of your connections.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 06-03-2016, 18:50
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
As others have noted, I would check the wiring carefully for shorts or open circuit. I would also check the roboRIO power light and DS power tab for 5V faults (they may also show up in the DS log, I'm not sure). It may be that metal debris in one of the connectors or inside the roboRIO case or a short on a different sensor is taking down your whole 5V rail which would cause the described symptoms.
Unread 16-03-2016, 14:04
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
I'm a little late here, but wanted to add my 2 cents anyway.
If your potentiameter is a single-turn(i.e. 210 or 360 degree) pot, then look for damage to the device. If it's a 360 model and turns past it's range, it may make contact with the other side and read the opposite value. We had this happen when our arm went too far in testing. It essentially pushed the pot housing apart a little, letting it spin freely. Resetting it to within it's valid range and tightening the housing down again fixes the issue.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
