Go to Post I think the new smoke cost about $ 189 from AndyMark. - ebarker [more]
Unread 06-03-2016, 20:37
beerobber beerobber is offline
AKA: Chris Taylor
FRC #5582 (Rex Machina)
Team Role: Coach
Rookie Year: 2015
beerobber is an unknown quantity at this point
PCM behaving strangely: compressor short, sticky fault, intermittent functioning
I need some tips on how to diagnose potential PCM issues.
Our PCM operates intermittently. When we enable the robot, the compressor will give a little sputter, then the PCM will blink orange. The NI console reports a compressor short. But if we wiggle the wires, or ignore that issue and focus on other things, typically the compressor will kick in a few minutes later. It won't run smoothly, just 4-5 seconds at a time until it finally builds up to 120 on the high side. Might take 5-7 minutes to get there.
The solenoids won't fire reliably through the PCM. They work great manually, but during the times the compressor isn't running and the light blinks orange, they won't respond to code control.
We have replaced the compressor. We have replaced the PCM. We have run new power wiring from the compressor to the PCM. We've isolated the PCM on the CAN bus. None of these things made it reliable. The new PCM seemed to get itself into a working state a bit more frequently than the old one.
This is a tense moment for our team. Our first district event loads in Thursday night. We spent 4 of our 6 out-of-bag hours tonight, and we have 2 left. So with the robot in the bag, I can't take pictures and I can't try your suggestions until tomorrow night. But please load me up with ideas so we can get this issue cleared!
Here are some things I've read on other threads:
- Try moving PCM further from radio (not sure this will be possible, but we can try some shielding material to block RF temporarily for troubleshooting)
- Reapply firmware
- Use Weidmuller ferrules like http://www.ctr-electronics.com/cabli...le-16-awg.html
- Make sure CAN isn't running parallel to power
Thanks in advance for your suggestions.
--Chris
Unread 06-03-2016, 22:34
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
Rookie Year: 2010
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
Re: PCM behaving strangely: compressor short, sticky fault, intermittent functioning
We had exactly this issue during our week 0 scrimmage. We changed compressors, PCM, wires, re-imaged the PCM, same problem, just like yours. We had our router mounted on top of the RoboRio and the problem went away when we moved it about a foot away from the rest of the electronics. We did another 4-5 hours of testing after the fix and never had the issue again. Best of luck and I hope you can fix the issue.
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
Unread 06-03-2016, 22:37
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
We had that issue and it went away as soon as we moved our radio to the other side of our robot.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 06-03-2016, 23:49
AKA: Chris Taylor
Team Role: Coach
Rookie Year: 2015
Interesting. We will give that a try. Finding a new home for our radio will be a challenge in this year's robot designed to go under the low bar, but we'll do it if it means working pneumatics! I'll post tomorrow night with updates.
Any further suggestions are welcome.
Unread 08-03-2016, 07:17
AKA: Chris Taylor
Team Role: Coach
Rookie Year: 2015
Talking Re: PCM behaving strangely: compressor short, sticky fault, intermittent functioning
Success! Thanks for the tips. I don't know when we would have ever thought to create separation between the radio and the PCM, but that did it.
Our PCM was less than 1 inch from the radio. Our first validation was to slide a triple-thickness sheet of aluminum foil between those components, and that was enough to allow the compressor start immediately and run until the pressure switch cut it off. Solenoids are also reliable. The PCM is signaling green and happy.
After a quick debate about the appropriateness of aluminum foil as a crucial component in a competition robot, we moved the radio (only 2 wires) and used zip ties to give it a new home about 9 inches from the PCM.
Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. So it came off before the robot went back in the bag.
Unread 08-03-2016, 21:35
DonRotolo's Avatar
Back to humble
FRC #0832
Aluminum is almost OK as a shield, except that it only conducts electricity and not magnetism. An electromagnetic field has both electrical and magnetic components, and you should want to shield both when possible.
Of course, moving the radio was the better solution.
Unread 09-03-2016, 00:55
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
Rookie Year: 2011
scca229 will become famous soon enoughscca229 will become famous soon enough
Something just got added to my list of things to look for if a team's bot is acting erratically and they don't have a clue as to why...
Thanks for the follow-up from an appreciative FTA.
Nate
