Re: Is OPR an accurate measurement system?
Simple answer: It's not a great measurement this year but it's certainly better than the rankings
OPR using match scores can be misleading.
Finding component OPR numbers can be useful depending on what you are looking for. |
To get the right answer, you first have to ask the right question ....
"... all models are wrong, but some are useful."And OPR is what is it is; and the OPR equations compute OPRs 100% accurately.George Box You need to ask/determine whether OPR is a useful tool for your purpose (or ask what things OPR is useful for). I personally think that Chairman's Award submissions are a better (but still imperfect) tool to use than OPR is, if I'm (quoting the OP) searching for "... the best teams in FRC." ![]() Blake |
Is anyone actually going to be computing component OPRs this year? I believe Ed Law is not doing that this year, so I need to find a new master scouting database to reference.
As far as how it works, the simplest explanation is that OPR is the assumption that every robot always contributes the same amount of points. This assumption is obviously false, but it's often close enough that it can still provide useful data. Learning how this calculation is done is honestly not that hard, and it can provide some useful insight into the limitations and capabilities of OPR. |
Pretty pretty please do. I might do it myself if no one else does, but the earliest that would happen would be late next week when I am on spring break
Yes.
#11
This comes up pretty much every year, the best answer is "it's okay", but the most important part is to understand how it's derived which Jared explained very well. If you understand what it actually means then it's a very useful tool.
#12
The most important part is how much you can learn by studying how it's derived.
#13
I took a class this summer on Sabermetrics and the baseball world is just nuts over different models over different data sets. They are tracking temps, wind speeds, humidity, etc on top of all the other data that they gather. I'd consider OPR to be a poor cousin to Sabermetrics WAR. |
#14
This. Too many people bash on OPR, and not enough people bash on the rankings.
#15
With the data that FIRST provides through the FRC Event API, we can certainly do much better than your typical OPR. For example, I can pull down that data and know exactly which defenses were on the field and which of those were crossed and damaged in every match any team played in. I can know exactly how many balls were scored in which goals, how many robots challenged, and how many robots climbed. Proper statistical analysis (think OPR, but for each individual category instead of just overall score) can get you much more detailed and specific data. It won't be the whole story, but I would be willing to bet it would be more accurate than just the overall OPR. And more useful in assembling an eliminations alliance with the capabilities you want.
