Boulder Starvation
Has anyone seen a strategy (preferably in the elims) where an alliance purposefully attempted to keep boulders out of the middle of the field?
I've been thinking about game strategies and comparing things to past gameplay while prepping for our regional this weekend. Something I've noticed is that the secret passage reminds me a lot of the human player station safe zone from 2011. I'm sure others have realized this also. I remember an example of this strategy from 2011 at silicon valley. 1323, 604, and 1868 almost beat the power house 254 alliance by starving them of inner tubes. http://www.thebluealliance.com/event/2011sj You can see that the finals scoring is much lower in the final rounds than the other elims. I know it's only week one, but there's already been a ton of gameplay. Just thought I'd ask the community. |
Re: Boulder Starvation
I watched several times where balls simply accumulated at the end of the secret passage. The first couple balls just stay there by chance, or maybe having a robot push them there, then the new balls being introduced to the field roll into the ball blockage and stay there. At one regional I saw a ball pile with 10 balls, that is over half of the balls in the game.
It is then annoying to grab those balls now since you have to be careful about grabbing two, to avoid penalties, while not driving on top of the balls. Edit- added image Last edited by Procolsaurus : 07-03-2016 at 20:52. |
Its a valid strategy as most hybrid-boulder bots will have longer cycle times than a dedicated starving bot.
What is a "hybrid-boulder bot"?
What I call a decent crosser and HG/LG shooter so there cycle times are lower as they can cross most defenses.... I just coined that term..basically mid level captain types as breachers usually will rank higher in quals
I differentiate those that only can cross one or two defenses...from those that can pretty much breach and shoot The types that beat us (with our shooter malfunction) in SD and eventually won it. Last edited by Boltman : 07-03-2016 at 19:27. |
If you're not doing this, what game are you playing? This is a much more effective form of defense than a lot of the physical defense you can do this year, and ball control is absolutely critical to winning in elims and trying to prevent captures at all costs. Human players need to bowl well and time the bowls appropriately or you're just giving your opponents points.
Are you allowed to shoot a ball over the outer works and do some thing along the lines of what 16 did in 2012 and just feed your own team boulders and starve the other alliance?
No, you can't shoot a boulder unless you're in your opponent's courtyard, though i like the reference to 2012.
If you dump a lot of boulders into your opponent's secret passage, the opposing alliance has much more access to those boulders due to being able to cross from the neutral zone to the secret passage and back. I think it's possible, and I wouldn't be surprised if we saw some strategies aimed at this, especially later in the season, but I think it is very risky. |
#11
(Your opponents can't cross from the neutral zone to your secret passage, that incurs penalties) I'm very curious to see how these strategies shape up in the coming weeks, rather than in my theoretical math. |
#12
What makes more sense is "starve and score" win/win Not starve and keep boulders away from your scoring area Last edited by Boltman : 08-03-2016 at 08:26. |
#13
However, this appears to be a niche case, because if you have that much of a lead, you're likely to win regardless of what you do at that point. |
