Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 07-03-2016, 18:39
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
Rookie Year: 2014
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Auto damage
Can you, with respect to the rules, not feasibility, damage a defense during auto?
Unread 07-03-2016, 18:46
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Auto damage
Feasibly? Yes, but it would take two robots, and one of them to have an auto that can turn and follow a robot through a defense.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 07-03-2016, 22:41
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Auto damage
Unless the two robots in question can only cross that one defense, what is the benefit? Damaging one defense scores the same as single crossings of two defenses, whether in auto or teleop.
If your auto routine is able to cross three categories of defense (in our case, low bar, B or D), you should always be able to have your own defense to cross for auto.
Unread 07-03-2016, 23:16
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
FRC #1675 (Ultimate Protection Squad)
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Re: Auto damage
I see at least two benefits to being able to cross a defense after another robot.
1) Low bar will likely be the most consistent location for auto routines. This is both because it will be in a consistent location, as well as the fact that the low bar is probably the least likely to cause alignment issues while trying to cross it. I have a feeling many teams would be more consistent scoring with 2 low bar routines (for being 1st bot and 2nd bot through the low bar), than trying to score a boulder after crossing the rock wall or rough terrain.
2) Having a second bot run through a defense could set you up to run a 2-ball assist auto with a high shooter and an assister.
