Talon SRX in PID Speed mode won't stop!
Hi!
We have a Talon SRX (to a CIM motor, with a quadrature encoder) - it's attached via a pullup / breakout board to the encoder. On our test robot board (no robot, just control system), it seems to behave as expected: using control mode kSpeed - ... (pseudo-code): if (button1) { talon.Set(1000.0); //turn it on. } if (button2) { talon.Set(0.0); //turn it off. } - the talon starts and stops when commanded. On our real bot, though, it won't stop once started. (we also tried putting it in voltage mode; in that case ![]() (pseudo-code): if (button1) { talon.Set(1.0); //turn it on. } if (button2) { talon.Set(0.0); //turn it off. } Which works fine. Stumped! Martin Haeberli (de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT) |
