Go to Post I think that is important to note that winning teams have won without bending the rules. GP allows you to go ask, investigate and take pictures. Learn from others when you have the chance. - Al Skierkiewicz [more]
Unread 08-03-2016, 10:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
FRC API
I have an FRC API Python script that I used (successfully) one year ago this month to retrieve some data.
Now when I run the script I get this error:
urllib2.URLError: <urlopen error [Errno 10061] No connection could be made because the target machine actively refused it>
So I was wondering if there is an effective process in place for getting assistance with FRC API errors. A help desk if you will. Or a guru here on CD.
Unread 08-03-2016, 10:14
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
Rookie Year: 2013
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
Have you changed the URL to reflect FIRST's URL change from usfirst.org to firstinspires.org?
Unread 08-03-2016, 11:30
Ether's Avatar
Rookie Year: 1969
Re: FRC API
Yeah, that was it. Reps to you
Unread 08-03-2016, 11:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: FRC API
Ether - I use the API to calculate the official rankings for the MN State Championship (at least, last year and this year). While I have it all set up in Java, if be happy to help if you run into any more issues. I know the domain change hit me earlier this year as well!
Also, there is the official teamforge page for the API - I don't know how often people check the discussion board there, but it could be another place to look for help.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 08-03-2016, 11:43
Ether's Avatar
Rookie Year: 1969
Re: FRC API
Thanks Jon I will keep that in mind.
Unread 08-03-2016, 11:50
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Re: FRC API
According to their TeamForge page:
Tokens are removed if the account is inactive for over 6 months (0 requests), or has been banned for one month without contacting us. If your token disappears, just send us a message and we'll help you out.
Unread 08-03-2016, 11:53
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: FRC API
Here is a like to the apiary page that contains the full api docs (there were some updates for 2016):
http://docs.frcevents2.apiary.io/#
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 08-03-2016, 12:21
Ether's Avatar
Rookie Year: 1969
Re: FRC API
Thanks for pointing that out.
That's a very ill-conceived policy for something annual like FRC. It should be at least a year, if not 18 months.
