Go to Post [in best Tom Hanks voice] Are you crying? ARE YOU CRYING? There's no crying! THERE'S NO CRYING IN ROBOTICS! - dlavery [more]
Unread 08-03-2016, 18:25
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
RSL mounting rules
I'm wondering if I am interpreting the rule about visibility of the RSL correctly.
Any RSL must be:
A. Mounted on the robot such that it is easily visible while standing three (3) feet in front of the ROBOT
Does this mean you only have to see it from the front or do you have to be able to see it from all sides? This would affect if I have to mount a second RSL to the back of the robot.
Thanks
Unread 08-03-2016, 18:38
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Re: RSL mounting rules
The RSL only needs to be visible from the front of the robot standing at least 3 feet away. However, you may run into an issue during inspection so if you can your best bet would be to mount a second RSL.
Unread 08-03-2016, 22:17
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The RSL is there as a diagnostic, both to the field crew and your drive team. Ours is currently visible from three sides, so we're adding a second light to ensure full visibility. (Yes, this is why I asked Q927.) (Note to self - get Veronica to add enabled/disabled to the spy signals.)
