Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 09-03-2016, 00:42
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Talon SRX / VersaPlanetary encoder parameters?
Hi!
We are trying to figure out how to use and configure Talon SRX with VexPro VersaPlanetary encoder on a 63:1 gearbox.
We're running it directly to the Talon SRX with the weird special cable...
We already (think) we figured out that we have to call either of:
talonSRX.SetSensorDirection(true);
talonSRX.SetClosedLoopOutputDirection(true);
But can find no documentation on what, if anything, to do with:
talonSRX.ConfigEncoderCodesPerRev();
Some documentation claims that the right thing happens, magically, without setting this value.
Another document suggests that the actual value is 1024.
And, only when we call:
talonSRX.ConfigEncoderCodesPerRev(1024);
Do results seem sort of reasonable.
Suggestions welcome.
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Unread 09-03-2016, 00:48
wsh32's Avatar
wsh32 wsh32 is offline
The Nerdiest of the Nerd Herd
AKA: Wesley Soo-Hoo
FRC #0687 (The Nerd Herd)
Team Role: Leadership
Rookie Year: 2014
wsh32 is on a distinguished road
Re: Talon SRX / VersaPlanetary encoder parameters?
You should call talon.setFeedbackDevice(FeedbackDevice.CtreMagEnco der_Absolute); (or CtreMagEncoder_Relative depending on how you want to use it). Setting the feedback device to the CTRE Mag Encoder presets all the settings so you don't need to call the configEncoderCodesPerRev.
Unread 09-03-2016, 09:05
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Checkout section 17.2 in the talon srx software reference manual.
