Go to Post We just need to make engineering an interesting everyday thing, as visible as art exhibits or concerts or football games. - Alan Anderson [more]
Unread 09-03-2016, 13:27
cpapplefamily cpapplefamily is online now
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Testing SmartDashboard Tools Display Subsystem Status
I have been testing tools the team has never used but I see Value in. I tried to add my subsystem status on the SmartDashboard by using:
Code:
public void robotInit(){
SmartDashboard.putData(mySubsystem); //Works
//and
SmartDashboard.putData(myPIDSubsystem); //Does Not Work
The normal system display as expected the PID has Nothing. Is the PID system Not usable this way?
Unread 09-03-2016, 19:34
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: Testing SmartDashboard Tools Display Subsystem Status
The PID subsystem works quite well last I checked, you had the normal options for a command plus some tuning widgets for the PIDF constants. Check your code (command code and SD code (reset all if you aren't doing anything special)) and see if you can find an issue, if not post here.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 10-03-2016, 00:09
Rookie Year: 2015
The live window works fine. I was looking for subsystem status in teleop.
