Go to Post it's possible, based on his widespread approval, that Frank is in fact a collection of kittens in a human suit - Andrew Schreiber [more]
  #16   Spotlight this post!
Unread 22-03-2016, 14:20
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: Longer battery wires
Originally Posted by philso View Post
I'll take your word that the crimps were good and the screws and nuts are tight. What sort of motors did they have in their drivetrain? How much wire was removed from the loop in total?
My gut feeling is that if cutting out a few feet of wire made that much difference (you probably didn't cut out 12 feet or even 6 feet if they started with 6 feet), they are probably still just above the brownout threshold of 6.8 V. It is likely that they still have some other issues such as batteries with high internal resistance and that it is likely that their brownout problems will return.
6 CIM drivetrain and a couple of minicims on an auxiliary mechanism.
The loop was 6 ft for both black and red wires (12 ft in total). When I told them to chop it off to a minimum, I came back and saw that they had just under 1 ft for both black and red wires.
The problem went away.
High current draw across 6AWG *DOES* result in a large voltage across a long span of wire.
Physics doesn't lie unless you do the math wrong.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
  #17   Spotlight this post!
Unread 22-03-2016, 14:46
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
If they really are pulling that much current and had an extra 6 feet in both the red and black, it makes sense that it would make a difference. I am very familiar with how to do the math but this information was not in your original post so I could only make assumptions about your example. Most of the time, when I see a robot with funky wiring (including that much extra), it was built by someone who also does bad crimps, leaves connections loose and abuses their batteries.
  #18   Spotlight this post!
Unread 22-03-2016, 15:10
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Originally Posted by Al Skierkiewicz View Post
OK,
running worse case calaculations, a four motor CIM drive will draw ~480 amps at stall. 480 amps will drop .48 volts for every 2 feet of #6, please include the red and black wire in your calculations. The 6 foot run would be 12 feet of wire added to the two feet on the battery and about another equivalent 2 feet for properly crimped connectors and terminals. That adds up to almost 4 volts dropped in just the wiring feeding the PDP whenever you start driving or reverse direction. Add that to the internal resistance of the battery and you potentially have only 3 volts available even on a fully charged battery.
Jumping back to my easy calculator the WIRE FOOT, every WF will drop 0.1 volt at 100 amps.
Battery Internal Resistance=11WF
1 ft. of #6=0.5WF
1 ft. of #10=1WF
1 ft. of #12=2WF
When you view your voltage logs, those short dips to the 4 volt level you see are real. Make your #6 run as short as possible. Often you can significantly shorten the run by simply turning the PDP 180 degrees.
But if there were only 3 volts at the motors, can they still pull 480 amps? I know it is a problem, but I don't know if it is that bad.
  #19   Spotlight this post!
Unread 22-03-2016, 15:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
No.
Remember Al said it was "worst case".
In this case, the estimate is quite pessimistic.
You could create a more complete model, including:
  • battery internal resistance
  • PDB resistance
  • wire resistance
  • crimp resistance
  • connector resistance
  • voltage drop across motor controller
  • motor resistance
... and then do a more accurate calculation to determine the various voltages.
  #20   Spotlight this post!
Unread 23-03-2016, 07:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
What I am trying to get you to think about is this...
1. All robot current flows through the #6 wire from battery to PDP.
2. Any resistance in that loop will drop voltage at a predictable value.
3. Worst case voltage drop will affect the voltage available for other systems.
4. The RoboRio is the most important followed by the radio for keeping available voltage as high as possible.
5. Regardless of your design, all motors draw stall current when starting.
6. Brownout voltage doesn't matter to motors if the control system has already died.
7. The voltage dips you see in your logs are real as measured by the RoboRio. This confuses most people but those dips do occur. The log is not lying to you. WildStang did some extensive research into this more than ten years ago. We were able to compare video and voltage data to show that certain behavior leads to voltage drops. We had developed an app for Blackberrry at that time to put it all together and generate warning messages for our drivers at that time.
Yes, motors will draw less current at a lower battery terminal voltage but they will also likely stay at near stall longer as drivers push the throttles to max to get the robot to move as they want. Turns will also push the current to extremes if you have a lot of tires or tank treads on the ground.
Al
WB9UVJ
www.wildstang.org
________________________
