Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
Unread 09-03-2016, 18:11
Dalas Dalas is offline
Design Lead
FRC #4585 (Husky Robotics)
Team Role: Driver
Rookie Year: 2014
Dalas is an unknown quantity at this point
What is the most (SKETCHY) thing you've seen on a robot?
So we're working on our climber now, and it struck us how incredibly ghetto (jurry-rigged, cheap, unrefined etc.) it is.
Ours has ground-down bolts, nuts used as spacers, angle ground gearboxes, a wrench as a ratchet, rubber bands, bent steel bars, ground down hex shafts a seatbelt, and generally a lot of crap. Here's pictures:
https://photos.google.com/share/AF1Q...ZGJGeGls M053
https://photos.google.com/share/AF1Q...VzZGJGeGlsM053
https://photos.google.com/share/AF1Q...ZGJGeGl sM053
Anyways I don't have the best hopes for our end-game this year (even if its my fault).
What's the most ghetto thing you've seen on your robot?
Unread 09-03-2016, 18:17
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: What is the most ghetto thing you've seen on a robot?
I have personally built far more janky robot parts than those and won events with said janky robot. Driving a janky robot very well is far better than driving a top tier robot poorly.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 09-03-2016, 18:20
Design Lead
Team Role: Driver
Rookie Year: 2014
Any pictures? Just curious
We got a fair amount of driving practice in before bag and tag, but this is my first time driving mecanum, and we have a pretty bad weight imbalance screwing with our strafing. Still hoping for a fun regional next week though, I'll drive my best!
Unread 09-03-2016, 18:40
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
In 2014, we had a linear ballista-style ball launcher that used really fat latex tubing. We were running into concerns about the wear and tear on the tubing because it only wrapped around two 1/4 bolts, and there was probably upwards of 150+ pounds of tension in the launcher when retracted. So yes, lots of pressure on a little surface.
It was evident that lubricant was necessary, but as the material was latex, we had to opt for water-based lubricant since oil-based lubricants degrade latex. Well, the only water-based lubricants available near the regional were in the form of personal lubricants at the nearby drug stores and supermarkets.
In our pit for the rest of the event, we had a tube of Astroglide covered with red duct taped and labeled "Secret Sauce." We applied a fresh coat to the latex tubing before every match.
Not sure if it's the kind of "ghetto" you're looking for, but it's certainly an unexpected fix to a problem. Worked like a charm, though.
Unread 09-03-2016, 18:51
TheBoulderite's Avatar
TheBoulderite TheBoulderite is offline
Director of Communications
AKA: Warren Bartlett
FRC #1619 (Up-A-Creek Robotics)
Team Role: Leadership
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
In 2013, our design was to have the robot drive to the HP station, be fed frisbees, and hold onto the frisbees until the endgame, where we would scale the pyramid and dump the frisbees into the top of the pyramid for points. The collector for the frisbees broke during the Quals of Colorado, and we ended up fixing it with duct tape and a Team Driven t-shirt.
2015-now: 1619 (Up-A-Creek Robotics)
???: 2017 Utah Regional, ???: 2017 Colorado Regional
Thanks to all of our alliance partners over the years!
(1583, 1667, 937, 1332, 1158, 1348, 2543, 2261, 1777, 2240, 2036, 3648, 1410, 3200, 3807, 4550, 399, 2594, 1987, 4153, 624, 4334, 1730, 4593, 3618, 3026, 967, 4499, 3009, 1011, 525, 4028, 3352)
Unread 09-03-2016, 18:57
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Dear Craftsman tools,
I am very disappointed in my 1/2" Craftsman ratchet. It doesn't perform nearly as I expect when jury-rigged into an FRC component. I'd like to claim on my lifetime warranty.
Dear FRC team,
Although we appreciate your talent and unique use case. We can't provide a replacement for a use we clearly did not intend.
Unread 10-03-2016, 05:08
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Dear FRC team,
Too Funny!
Maybe vendors will see the value in having an "FRC Robot Tested Tough" sticker on their products.
Like in the days of yore when Timex had funny ads showing how tough their watch was.
https://www.youtube.com/watch?featur...&v=ynSrvluQBy8
Unread 16-03-2016, 10:35
Moonsault's Avatar
Moonsault Moonsault is offline
It's only plywood and pool noodles.
AKA: Alex Sharpe
FRC #5484 (Memento Vitam)
Team Role: Human Player
Rookie Year: 2015
Moonsault is an unknown quantity at this point
Originally Posted by DaveL View Post
Too Funny!
Our team has used 3/8 wrenches in our super shifter.
Unread 16-03-2016, 11:14
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
FRC #0862 (Lightning Robotics)
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
Accepting the previous conclusions about choice of language, I'm rolling with "janky" to describe things that look like they shouldn't work, but do anyways (and as such, these are among the best moments for fond recollection in years to come).
You wouldn't know it by looking at our more recent robots, but 862 was once defined by our mastery of all things jank. With inconsistent availability of build spaces and a complete lack of precision tooling (our first in-house drill press was a pretty big deal), we promoted ourselves based on our "old school" build philosophy (if it requires any more tooling than a hacksaw and drill, it can't be done).
During my rookie year in '06, our team had an expanding hopper to hold poof balls; the walls of the hopper were made of fabric, which naturally kept getting torn. In between each match, we patched up any new holes with zip ties, until eventually we ended up with no fabric left at all; just a sheet of zip ties linked together like chainmaille.
(I would also call out our collection roller system from the same year, but that wasn't really all that janky; it just sucked.)
The next year in '07, we initially didn't give our claw enough leverage to consistently clamp onto the inner tubes and hold them stable; a couple of gel insoles zip tied to the claw helped to solve that problem with better friction.
(Don't even get me started on the janked-out ramp we concocted for other bots to climb on top of; alumalite sign panels were never meant for use as weight-bearing elements, much less with 2.5" swiss cheese holes drilled through them!)
During the '08 competition season, we discovered that we had vastly underestimated the side loads that our elbow joint would be subjected to; we managed to get by for a while, bending it back into shape in between each match with a pair of vise grips and our trusty dead-blow hammer... But when it snapped clean in two near the end of the competition season, we ended up needing to replace the whole assembly.
Later during the post-season, we wanted to protect our nice expensive mecanum wheels during demonstrations on concrete; for a while there, we ran the bot with strips of carpet zip tied to the wheels as sacrificial treads.
(We also ended up using the same carpet-tread technique a year later in '09, of course, to protect the FRC-mandated slick wheels!)
Unread 09-03-2016, 18:55
RoboChair's Avatar
We applied white lithium grease to the surgical tubing bundle of our 2014 bot. It kept disappearing so we kept adding more, worked fine all season.
Edit: also at our first event we had to C-clamp a major component(without it we couldn't shoot properly) into place after it broke, we then proceeded to run 2 perfect cycles back to back at Inland Empire with a seriously crippled robot.
Unread 09-03-2016, 18:56
chapman1's Avatar
chapman1 chapman1 is online now
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
I don't know about anyone else, but personally, I find the phrase "most ghetto thing" offensive.
Invite conversation about shoddy construction and poor taste if you want to, but to equate it to anything that comes out of poor urban areas reeks of classism and racism. It has no place here.
Unread 09-03-2016, 19:04
Shrub's Avatar
Shrub Shrub is offline
no team (N/A)
Rookie Year: 2014
Shrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant futureShrub has a brilliant future
Just gonna bump this. "Ghetto" being used to describe something negatively or of poor craftsmanship has a strong history of classism and racism. There are many, many other words out there that could have been used instead of "ghetto", and part of making FIRST more inclusive and welcoming to PoC and people from low income areas (which is what teams are looking for, or should be looking for), is eliminating language like this and using it in this way.
Unread 09-03-2016, 19:10
Aura_ Aura_ is offline
Rookie Year: 2013
Aura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these partsAura_ is infamous around these parts
Come on dude everyone knows what he means with ghetto do be so critical about it.
Unread 09-03-2016, 19:12
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I have a friend from a team that describes how sketchy an idea/solution is by removing letters from the word "sketchy." I've been a part of teams that got down to what I would consider "ske."
And yeah, no need to refer to badly-made robots parts as ghetto. There are plenty of other words that less people will find offensive that one can use.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #15   Spotlight this post!
Unread 09-03-2016, 19:13
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Come on dude, language changes and we learn to be more respectful of experiences that aren't our own as time goes by.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
