Go to Post Just keep doing. Everything. Keep designing, keep building, keep learning, keep fundraising. Build more robots, try more ideas, compete more and more and more. - [more]
Unread 14-03-2016, 20:49
JohnSmooth42 JohnSmooth42 is offline
Is writing code
FRC #0375 (The Robotic Plague)
Rookie Year: 2012
JohnSmooth42 is an unknown quantity at this point
Re: What is the most ghetto thing you've seen on a robot?
We had to fix our intakes at an off season event one year and we discovered a shaft key had come out. While looking for said shaft key we found a rivet on the floor. I don't think I need to elaborate on this any more...
Unread 14-03-2016, 21:04
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
In the same vain, HSS drill bits make crappy yet expedient dowel pins. Drill the hole and, while still running the drill, angle it to the side with a sharp jerking motion. Instint pinned connection. Back it up with a drop of CA glue if you're the nervous nelly type.
Unread 15-03-2016, 00:11
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
I was not able to witness the performance of the robot, but I remember in 2014 Aerial Assist, I looked down the end of the convention center and I saw a robot that featured a folding chair (with arm rests) as the catching mechanism.
Unread 15-03-2016, 00:24
Alex2614's Avatar
Alex2614 Alex2614 is offline
Scapegoat Mentor
AKA: Alex Stout
FRC #2614 (MARS)
Alex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud of
Send a message via AIM to Alex2614
Okay, okay, can we move past whether or not you think the title of the thread is offensive? We get it. You've all made your point. Now let's focus on the actual INTENT behind the words and what the thread was intended to be about?
MARS - Mountaineer Area RoboticS Team 2614, Morgantown, West Virginia Website Facebook Page
2016 season in memory of Phil Tucker
We came to be inspired. We stay because we are. We will become the inspiration.
2016 Championship - Newton quarter-finalist, Hopper-Newton Gracious Professionalism Award
2016 Regionals - Finalists (x2), Chairman's Award, Gracious Professionalism (x2), Industrial Design
2015 Championship - Hopper Finalists
2015 Regionals - Chairman's Award, Regional Champions, Gracious Professionalism, Woodie Flowers Finalist
2014 Championship - Innovation in Controls Award
2014 Regionals - Chairman's Award, Champions, Finalist, Entrepreneurship, Gracious Professionalism, Dean's List Finalist, Creativity
2013 Championship - Entrepreneurship Award
2013 Regionals - Engineering Inspiration Award, Entrepreneurship, Dean's List Finalist
2012 Championship - Woodie Flowers Award
2012 Regionals - Champions, Chairman's Award, Finalist, Innovation in Controls
Unread 15-03-2016, 00:47
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Had one of those at L.A., too.
This year, I've seen a robot that held its intake in starting configuration with... wait for it...
...Painter's tape. Yep, folks, painter's tape, 1" wide and stretched long. I knew they needed a new piece when they were trying to find a spot to stick the two pieces they made every time they went out for a match together...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-03-2016, 01:58
araniaraniratul's Avatar
araniaraniratul araniaraniratul is offline
294-Alum
AKA: Arani (Ron) Bhattacharyay
FRC #0973 (Greybots)
Rookie Year: 2010
araniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rougharaniaraniratul is a jewel in the rough
Send a message via AIM to araniaraniratul
So it was the same robot in Los Angeles and Las Vegas. In 2014, we (294) stuck a lawn chair on 687 because they had an awesome drivetrain but their other mechanisms were struggling. It helped them consistently get that first assist. They eventually grew out of the chair by the time eliminations in LV came around. I love bugging one of my co-mentors (687) about it though!
The Greybots
973
- Mentor
Beach Cities Robotics
294
- Student/Mentor
The Sloth Bears
5499
- Mentor
Unread 15-03-2016, 10:09
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
Rookie Year: 2010
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
The following story is not the most kludgey thing we have ever done, but it is one of the most successful kludges we have ever pulled off.
This year at Mount Olive, we took the robot out of the bag and noticed the intake arm was spinning loose on the shaft. We looked a little closer and somewhere between final testing and bagging the robot, the 3/16" key had fallen out of the sprocket. After looking through everything we brought we discovered that the spare key stock had not been packed. After calming down, we cut the heads off of some #10 bolts and shoved them into the empty keyways and re-tightened the retaining set screws with loctite and they held for the entire event.
Unread 03-04-2016, 19:23
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
Team Role: Leadership
Rookie Year: 2014
C.Lesco will become famous soon enough
Oh my god im so happy to hear that we werent the only ones doing this. Sketchiest thing, losing bolts on battery box, fixing battery box to frame using zipties which all broke at the end of every match.
All fixed for worlds though
Rookie Allstar winner North Bay regional 2016 [Team 5870]
Driver 2015 [Team 4814]
Lead Driver 2016 [Team 5870]
Build, Design and Engineering Captain 2016 [Team 5870]
Mentor 2017 [Team 5870]
Unread 14-03-2016, 21:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Sometimes people are just offended too easily. Sometimes offensively so.
For the record, in our neck of the woods we sometimes refer to this as "cajun engineering", in jest but not intended as an offense. Also for the record, the guy whose hands are in the picture that I posted as a "cajun compass" is not in fact a cajun, but I am at least 3/8 cajun myself, and I did not intend to be mean to either the man wielding the crawfish tray as a circle guide or to my own relatives. Nor do I believe any of them took it that way.
Chill!
Unread 07-04-2016, 23:28
Maxwellfire's Avatar
Maxwellfire Maxwellfire is offline
AKA: Max Tepermeister
FRC #2877 (LigerBots)
Rookie Year: 2010
Maxwellfire is an unknown quantity at this point
Originally Posted by nedwards28 View Post
2014 rookie year in aerial assist. Robot won't stay in correct configuration at match start. We used zip ties to hold the arm up and then used the autonomous to jerk the robot to a stop hard enough to break said zip ties. We also didn't have enough pneumatic guts to get the ball over the truss without a solid running start.
2015 recycle rush. Needed to spring load some clips that we're supposed to pick up totes by the handles during our second district competition. The only thing we had were hair ties from the girls on the team. Our running joke is that hair ties got us to Worlds.
Hair ties of various types are a continual sight on our robots: 2014 to retract the shooter after firing, 2015 to hold our sponsor panels on, and 2016 tbd
Unread 07-04-2016, 23:39
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
I had no idea Hartford did this for their 2nd event. This was their first year and they had some HUGE setbacks. Their main mentor was in a car accident and out for the season. We helped them to get their robot built and programmed. During St Joe, if my memory isn't failing which it always does, Enginerds, Rush, Robotarians and Joes helped them to build a catcher throughout the day. We ended up picking them for our 3rd pick.
Did I mention they had like 4 kids on their team? The girls on the team got to cheering for them because their ENTIRE team was on the field.
Here is a video: https://www.youtube.com/watch?v=72jV0C6NqkA
Now that post brought back some good memories. (BTW, we rearranged our numbers to make 5246, but we didn't have a 4 so we used a roughly 4 shaped giant head of our head mentor.
Unread 08-04-2016, 01:05
sir tyson sir tyson is offline
FRC #3999 (Shadetree Robotics)
Team Role: CAD
Rookie Year: 2016
sir tyson is an unknown quantity at this point
On this year's robot, our lift system consists of a tape measure connected to a motor with a hook duct taped to the end of it. The hook is attached to a "winch" (a hex shaft fitted through a socket wrench that's zip tied to the frame) with paracord.
Unread 08-04-2016, 12:13
PeeDiddy PeeDiddy is offline
FRC #3863 (Pantherbotics)
Team Role: Driver
Rookie Year: 2014
PeeDiddy is an unknown quantity at this point
We took the entire gearbox and motor assembly out of a drill and hotwired the motor controller to the arm of our robot to put it back in starting configuration post match every match.
Unread 15-03-2016, 17:47
KevinG KevinG is offline
Chesapeake District
AKA: Kevin
FRC #3650 (RoboRaptors)
Rookie Year: 1998
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
As a robot inspector I would immediately commend you guys for using a ratchet in such an innovative manner. I love jury-rigged stuff. In a competition full of beautiful robots made with CAD/CAM and precisely machined components I always enjoy seeing students who pull off an innovative solution using unconventional materials.
  #15   Spotlight this post!
Unread 16-03-2016, 08:46
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
As an urban educator, I commend the rational discussion in this thread regarding the language in the OP's title. I think we've arrived at a mature and reasonable conclusion.
That said, I also think that youngsters who are inculcated within a specific cultural context are not yet experienced enough to truly empathize with those in other contexts. This is not their fault, but rather just a lack of life experience. So, I want to provide some more information:
At our district regional this past weekend, the first thing my students-of-color said to me as we walked into the pit area was: "I don't see anyone else that looks like me."
How racism and classism operates is less and less on a personal level these days (which is good!), but more and more on an ontological and systemic level (which is pernicious!). Just go to Google Images right now and type in the word "engineer", and describe the top pictures that pop up. In fact, I'm gonna do that now! Here is what pops up for me:
http://i.imgur.com/pWbqtof.jpg
As you can see, beyond the lack of racial diversity in this representation, there's also a lack of gender diversity. This is emblematic of the normalization of certain representations of students of color. This normalization, which some scholars refer to as anti-blackness, is the ontological construction through media and narrative of what it means to be an urban youth. In essence, when we think about an "urban youth", whatever that may mean, the first images that pop into mind is not an engineer in a shirt-and-tie wearing a hard-hat.
And it's not just people who are privileged that carry those thoughts! Some of my students do as well! That's how pervasive anti-blackness is within our culture. I was judging a debate round once, when two teams were debating this very issue, and a student asked in cross-examination to another student: "Where is the black identity in America that is not equivocated with struggle?" Even at the regional competition this weekend, we were asked by our judges to juxtapose our success as a rookie team with our students' socioeconomic status.
Ultimately, this is why the language we use is super important. Yes, we can take back that term "ghetto", and yes, some of our students might not even see or take offense to that term. However, it's not just this one term. It is the amalgamation of the images and representations they see, the language they hear being used to describe them, the fact that their perception of the role of police in society is very different than majority culture, the fact that they can't hang out at a park in the afternoon without being harassed by authorities, etc. All of these add up to systemic racism.
I'll get off my soap-box now.
EDIT: That picture was gigantic.
Lead Mentor - Team 6367 - The Brooke High ElectroLights
Former Mentor - Team 5969 - The English Skunkworks
Former Mentor - Team 1754 - The Excel Nitro Knights
