Go to Post Removing too much of the challenge removes too much of the accomplishment when you solve the problem. Removing too much of the challenge removes too much of the innovation in the solutions... removing too much of the challenge removes too much of the fun. - dlavery [more]
Unread 09-03-2016, 19:19
sandiskthefrog sandiskthefrog is offline
FRC #0503
sandiskthefrog is an unknown quantity at this point
How to run GRIP in headless mode?
Hi y'all, I've been racking my brains trying to get GRIP to run in headless mode for our robot. I've tried running the following command:
Code:
java -jar C:\Users\Robot1\AppData\Local\GRIP\app\core-1.3.0-rc1-all [decentGripOutside.grip]
thru command prompt but it's telling me that it is unable to access the jar. I've checked multiple times that the path is correct and that there are no spelling errors. I've already consulted these links:
http://www.chiefdelphi.com/forums/sh....php?p=1537810
https://github.com/WPIRoboticsProjects/GRIP/issues/267
Any help is appreciated!
Unread 09-03-2016, 19:34
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: How to run GRIP in headless mode?
Headless mode on the laptop or headless mode on the RIO?
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 11-03-2016, 20:04
FRC #0503
I don't have a good grip on how GRIP works exactly (pun not intended, but appreciated nonetheless). Basically I'm trying to get my PC to do all the heavy lifting of applying filters in grip and calculating the network tables, and the only thing my robot needs to do is to get the network table values and use them in our code.
Edit: While I have you, does this
https://github.com/WPIRoboticsProjec...EW-FRC-program
mean that I only have to deploy once to the RIO if I have this in my code? Then it'll run grip off of the RIO next time I run my robot code?
Thanks.
Last edited by sandiskthefrog : 11-03-2016 at 20:19. Reason: Point of clarification
Unread 12-03-2016, 16:32
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
try this ....
Code:
java -cp C:\Users\Robot1\AppData\Local\GRIP\app\core-1.3.0-rc1-all edu.wpi.grip.core.Main  decentGripOutside.grip
Or this ...
Code:
java -XX:-OmitStackTraceInFastThrow -Dfile.encoding=UTF-8 -Duser.country=US -Duser.language=en -Duser.variant -ea -cp C:\Users\Robot1\AppData\Local\GRIP\app\core-1.3.0-rc1-all edu.wpi.grip.core.Main  decentGripOutside.grip
Unread 13-03-2016, 04:30
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Code:
C:\Users\Robot1\AppData\Local\GRIP\GRIP.exe --headless <file.grip>
No need to deploy first unless you're running on the RIO or something.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
