Robot Signal Light cable / connector?
What kind of connector is used at the Robot Signal Light end?
We have lost track of our cable. Thanks, Martin Haeberli (de-)mentor, FRC 3045, Gear Gremlins (formerly SWAT) |
Re: Robot Signal Light cable / connector?
Its one of those jaw connections where you screw them in with a flathead. I don't know what they're called
While not an exact equivalent, Phoenix Contact #1757022 will plug in and function correctly. It's just green instead of black.
Electroken,
THANKS - you helped save us! We found what appears to be the equivalent at Jameco - we needed it right away. It was: Jameco 2094590 http://www.jameco.com/webapp/wcs/sto... CID=CAT152PDF Best, Martin Haeberli (de-)mentor, FRC 3045, Gear Gremlins (formerly SWAT) |
Check at AndyMark as well.
