AndyMark RAW Box and Potentiometer
Hi!
We're using an AndyMark RAW Box as the gearbox for our angle changer mechanism for our shooter, but we want to have a reliable way of determining the angle of the shooter, which will not depend on position at the start of the match (so preferably not an encoder, we're leaning towards using a potentiometer). Have any teams successfully attached a potentiometer to an AndyMark RAW Box, and how have you done it (or any gearbox with a threaded output)? |
Re: AndyMark RAW Box and Potentiometer
Since the AM RAW box already has the encoder mount for the E4T, you might be able to add a limit switch or hall effect sensor somewhere else on the mechanism to give the encoder a reference point. This way, you can use the encoder for absolute position. We used this approach on our 2015 elevator and it worked perfectly.
Another option is to use the AM String Potentiometer and attach it to the base of your robot and the string to the mechanism: http://www.andymark.com/product-p/am-2674built.htm |
Watch speed and backlash.... That homing routine is ok for most FRC applications, in industrial servo systems, the homing routine is...
Advance toward switch high speed. Trip switch, reverse direction, run slow, release switch. set zero. This method puts the gear backlash behind you... The direction you need to move off zero, the gears have already meshed to drive that direction. Probably over kill if you only have the one gearset, but if you have multiple gears, the backlash adds up. |
Also, you might try adapting the e4p mounting for an SRX Mag Encoder You can use that in absolute mode. The mounting should be quite similar to the e4p, but you'll have to drill a hole in the shaft to put the magnet in. |
Hmm, we haven't run into that problem yet, but what's the alternative you are using?
#11
Our arm assembly was also very heavy at that point because it is an intake and shooter. We lightened the intake considerably after that event. Depending on the weight of your arm/violence of movement, a raw box may be sufficient. |
