Go to Post He is just one of the dozens of evil minions I have molded into my image over the years. Be afraid world, be very afraid. - Andy Grady [more]
Unread 12-03-2016, 00:16
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
Team Role: Leadership
Rookie Year: 2014
C.Lesco will become famous soon enough
pic: Triwheels
Unread 12-03-2016, 00:23
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: pic: Triwheels
Looks like an innovative solution to getting over the obstacles
You might want to be careful about your choice of axle material, 1/2 inch Churro shaft really isn't known for being a good material for live axles, it is very useful for spacers and stand-offs, but not for things which take a lot of load.
This thread has a little bit more information
http://www.chiefdelphi.com/forums/sh...xle+materi al
If you have can afford the time and have the weight, it would recommend the switch to 7075 1/2 Hex shaft(Available from WCP/VEXPRO/Andymark) before your North Bay Regional
Unread 12-03-2016, 00:40
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: pic: Triwheels
Cool idea. I concur about the churro probably not being the best axle material however. We have seen that you can tweak a churro just using holding together a chassis, and I would assume there would be a similar load on your axles. Also I second this hex shaft from VexPro. We used some of it this year and it's held up real well.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 12-03-2016, 03:16
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: pic: Triwheels
What does the gearing on the other side look like?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-03-2016, 06:43
C.Lesco's Avatar
Rookie Year: 2014
Re: pic: Triwheels
Sorry if i knew how to upload a picture directly to the chat i would, i can send you a picture lster today since im taking off to watcha regional but short story.
Altogether 7 gears per wheel, i forget the exact ratio but its 2:1ish. All gears from vex, center gear drives 3 small idler gears which inturn drive 3 large gears. Quick fun fact, there are no bearings on the 0.5 inch hex idlers and they just free rotate around a bolt
Unread 12-03-2016, 06:45
C.Lesco's Avatar
Rookie Year: 2014
Re: pic: Triwheels
And i will look into buying a half inch hex for the axles, thanks for the input guys!
Unread 12-03-2016, 06:49
pilleya's Avatar
Elec+Mech
Rookie Year: 2013
Re: pic: Triwheels
Why go for idler gears, surely it would be simpler to just have 1 large gear turning 3 large gears attached to the wheels and do the 2:1 reduction else where, such as with the belts/ chain driving the modules or in the gearbox ( custom 3rd stage to get adequate reduction etc)
Also were the plates made by hand?, looks like some pretty precise metal work
What you ended up with looks very nice, what made you change your plan about making custom gears rather than purchasing COTs ones, you seemed set on making them earlier in the season.
Unread 12-03-2016, 19:42
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
FRC #4462 (Full Metal Jackets)
Rookie Year: 2013
Cothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant futureCothron Theiss has a brilliant future
Re: pic: Triwheels
I'm not on the OP's team so I don't know, but I assume it is because if the driving gear was large enough to contact the three driven gears, they wouldn't get the 2:1 reduction they need. The driving gear has to be small enough for the desired reduction.
Unread 12-03-2016, 20:09
pilleya's Avatar
Elec+Mech
Rookie Year: 2013
Re: pic: Triwheels
http://www.chiefdelphi.com/forums/sh...d.php?t=142662
The OP was originally planning on custom machining the gears for this, they may have been planning to make large ones( almost wheel diameter) to get the required reduction with 4 gears, but they didn't end up doing this. Probably a good choice to, machining gears is hard work and very time consuming.
Unread 14-03-2016, 03:13
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: pic: Triwheels
How are they on stairs?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 14-03-2016, 03:29
pilleya's Avatar
Elec+Mech
Rookie Year: 2013
Re: pic: Triwheels
Originally Posted by Mike Marandola View Post
With 6 wheeled trolleys, it is usually the pulling motion that allows the trolley to climb stairs, the person pulling it up the stairs is standing at around 45 degrees upwards of the trolley, so there pulling is what is actually causing the tri-wheels to jump up each step, if you tried pushing it up it wouldn’t do much. The key I see to the tri-wheel style obstacle crossing mechanism is that the distance from bottom of the wheel to the tri-wheel pivot, must be greater than the maximum height of the obstacles is has the cross(sort of obvious). Last year we asked to borrow a trolley from our school’s maintenance department/people and they gave us a 6-wheel trolley where each wheel was a very rugged 125mm Omni-wheel.
Unread 16-03-2016, 01:26
C.Lesco's Avatar
Rookie Year: 2014
Re: pic: Triwheels
The assembly would flip in the wrong direction if it didnt have idlers. I personally plasmacut the plates mtself with team members helping to file so thanks and im suprised you remember that custom gear thing. We took the advise given to look elsewhere and we were ashamed to find vex selling the gears we needed off the shelf. So lesson learned lol
Unread 17-03-2016, 09:22
pryland pryland is offline
FRC #4336
pryland is an unknown quantity at this point
Re: pic: Triwheels
We started on this path, but 3 weeks into build we discovered the colson's would just sit and burn rubber. Not rotation around the center unless we wrapped the colson's in sticky tape. Decided to pursue plan "B".https://drive.google.com/file/d/0B4h...ew?usp=sharing
Unread 17-03-2016, 09:46
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
Rookie Year: 2014
daliberator will become famous soon enoughdaliberator will become famous soon enough
Re: pic: Triwheels
Are those 3D printed sprockets? That's a cool way to prototype.
4536 Team Captain
www.minutebots.org
  #15   Spotlight this post!
Unread 17-03-2016, 09:51
Rookie Year: 2013
Re: pic: Triwheels
Getting files for Vex gears and sprockets is a great idea. You can change the tooth count in about a minute in the file, and then print them off in a short amount of time.
