Go to Post Ha, our 2009 robot's nickname was Sparky, for the same reason...we now have EXTRA fire extinguishers because of it ;P - Karibou [more]
Unread 14-03-2016, 22:52
zinthorne's Avatar
zinthorne zinthorne is online now
AKA: Avery
FRC #5827 (Code Purple)
Rookie Year: 2013
zinthorne will become famous soon enough
Dart actuator problems
This last weekend in glacier peak we ran into a significant problem with our dart actuators. During the competition we had the small metal gear that drives the plastic potentiometer hear slip. The metal gear would spin freely from the lead screw shaft causing all our values to be wrong. A few weeks earlier we thought we blew out the potentiometer on the dart from our backup bot, but it turns out that it was the same problem. We found that out when we disassembled it for parts during the competition. Needless to say it cost us one match and 2 more matches of having to drive our shooter arm manually which greatly hurt our scoring ability. We tighter the gear and loctited the appropriate threads to ensure the gear would not slip again. We then spend two hours re doing all our potentiometer values for our shooter arm. Everything ran okay for 5 matches until the gear started slipping again and then spun freely in our first quarterfinal match. We reverted to all of our manual override code. We had to run the rest of the competition by manually moving the arm up and down and guessing. Needless to say it nearly cost us the competition win when it went to three matches in semi finals and finals. We were forced to shoot low goals in semi finals to ensure we could capture the tower to win the match. In the finals the number one seed and captain of our alliance broke an axle on their arm so they sat out the first match. In that match we decided to guess and shoot in the high goal because we were then required to shoot and breach the defenses as well. (The third robot on our alliance was having radio issues so they were intermittent) Through eye balling all our shots we made all but two of our shots(one bounced out of the goal) and lost 103-102. The second match our alliance captain returned and we were able to barely squeak out the win 2 versus 3 because our third robot was completely dead the whole match. Match 3 we called a replacement and were able to seal the win. Needless to say the dart gear problem nearly cost us the competition so please check your actuators as well and make sure you don't have this problem! Just a heads up both of our dart actuators have seen heavy use. The competition boy one that broke ran 1.5 competitions before breaking and the practice bot one ran for many hours of use. We never ran the darts to their minimum or maximum during competition. We have hard stops that prevent that as well as software stops.
Has anybody else had this problem? If so how have you fixed it?
We are planning to put a versaplanetary encoder on our drive motor as a back up to the potentiometer. We have also ordered 2 new dart actuators for our next competition.
In the video you can see us almost grind through the upper stop on one of our early shots. You can see the arm go up and shake a little bit. I misplaced how high I had the arm and nearly broke the actuator because of the potentiometer problem. http://youtu.be/6vSVXhak_Wg
Unread 15-03-2016, 07:57
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
Re: Dart actuator problems
We originally tried to use the potentiometer but after breaking on and the other one being inaccurate, we just took then off. We just put an extra gyro on the arm and use that to tell the angle of the arm.
Unread 15-03-2016, 16:34
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We had the same issues. The best solution I have to offer is to put way more red loctite in there than you think you need, then tighten it way harder than you think you need to. We also tightened the plastic gear onto the potentiometer with what was probably unnecessary amounts of force after it slipped a little.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
