Go to Post Finally I wish everyone here on ChiefDelphi good luck and more importantly a fun build season. - mechanicalbrain [more]
Unread 15-03-2016, 18:41
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
How to attach gear to Banebots 550
Our team has a slight problem. When we were testing our ball collector mechanism, we burned out the Banebots 550 running the collector. It was connected to a Banebots gearbox (1:16 gear reduction, I think). We kept the motor and gearbox off the robot so we could get a new motor and replace the motor and gearbox at our competition as part of our withholding allowance.
Now here's our problem:
We got the motors yesterday, but they don't have the drive gear on them (which is expected). We had another mentor that mentors for a few teams that we think was the one who attached the gear to the previous motor.
We want to know how you would attach the gear to the drive shaft. We can guess how, but we want to know how to do it correctly.
Thanks,
Team 2855
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 15-03-2016, 20:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: How to attach gear to Banebots 550
Use an arbor press or a good quality mill vise and press it on. Be sure it's aligned and straight, and go slow. Also, be sure to support the back end of the motor shaft, so you are pushing through the shaft, rather than on the motor can or terminals.
Unread 16-03-2016, 10:45
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Follow-up question: can we reuse a gear from another 550? (Specifically, the one we burned out)
2. Wire the robot
7. Be active on CD
Unread 16-03-2016, 11:01
Chris is me's Avatar
AKA: Pinecone
If you have a gear puller and the gear is in good shape, you may be able to remove the pinion from the old 550 and reuse it. Just be careful not to damage the teeth in this process and you should be fine.
Unread 16-03-2016, 17:03
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
Rookie Year: 2014
ImMoMo is an unknown quantity at this point
Hey!
When I assembled our Banebots planetary to work with our Vexpro motors, I used a bench vice to attach the pinion gear onto the motor output shaft. Although I probably wouldn't recommend a bench vice, if it's what you have available, then it's probably your best option. A arbor press is most likely the best method for a task such as this.
Remember when you're pressing the gear onto the shaft that everything is level and straight, and that you are supporting the end shaft.
Just be careful you don't press the pinion gear on too far, just put it on far enough so it's fully on the shaft end, but not all the way down.
There's a little video on a similar gearbox from banebots, I used it as a reference.
https://www.youtube.com/watch?v=ZLLQXDcXAKE
As for taking off the other gear, I would recommend a gear puller, or if you don't have access, two screwdrivers to pry it off. Just be careful not to mess the gear teeth up.
Unread 16-03-2016, 18:05
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Thanks for all the help
We got the gear mounted on the new motor and the gearbox back on too and they both work perfectly.
We did use two screwdrivers to pry it off and a bench vice to put it on, because that's what we had.
Thanks,
Team 2855
2. Wire the robot
7. Be active on CD
Unread 16-03-2016, 19:02
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Nothing wrong with using a bench vice, I've used one many times at competition when needed Of course, an arbor press is a much better tool to use when you have access to one!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
