Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 16-03-2016, 22:23
voidpigeon voidpigeon is offline
FRC #1515 (MorTorq)
Rookie Year: 2014
voidpigeon is an unknown quantity at this point
Presenting MorScout - FRC scouting system for iOS, Android, and web
MorTorq Team 1515 is proud to present our newest iteration of MorScout!
Web: http://www.scout.morteam.com/
Android: https://play.google.com/store/apps/d...m1515.morscout
iOS: In Apple Store approval process - coming soon
What is MorScout?
MorScout is a user-friendly FRC scouting application available on iOS, Android, and web clients. It allows teams to create a custom scouting form, record match data, and compile information to improve match performance and assist in alliance selection. We’ve completely revamped the system from last year by creating a central, easy-to-configure server, improving the UI, and adding a ton of new features.
Why use MorScout?
Custom scouting forms are the key new feature in this year’s version of MorScout. Both match and pit forms are completely customizable so that you can record all of the information that you need and none that you don’t. To save some time, we’ve already made a default form for Stronghold, but you’re free to add or remove any data points you’d like. We’re still working on some features, like easy data point reordering and updating, but we will push that out as soon as possible.
We’ve integrated MorScout with MorTeam, our team management system, creating one network for all of your FRC needs. However, you do not need to use MorTeam if you don’t want to. MorScout streamlines user assignments as individual scouters can be assigned matches and corresponding teams through the application, eliminating the need to keep track of who scouts which team. Scouting data can either be retained privately in your team or shared publicly to help teams who don’t have the ability to collect detailed match or pit data. You can also view the data of any other teams that are kind enough to make their data public.
“OurScout is MorScout than YourScout”
