Go to Post However I did tell my wife I wanted to lose 20lbs of ugly fat quickly. She told me to cut off my head. Go figure. - Ed Coleman [more]
Unread 17-03-2016, 21:39
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
US Digital Shaft Encoder and VersaChassis Hex Shaft
We are running a west coast drive with a WCP DS Gearbox, and as suggested, we attempted to use a 1/4" US Digital shaft encoder on an output VersaChassis hex shaft. However, the hole on the shaft seems slightly too big for the encoder, as the encoder shaft slides in and out of the hole in the hex shaft very easily. There doesn't seem to be enough friction to move the encoder shaft along with the turns of the hex shaft. What is the correct way to mount these encoders to those hex shafts?
Unread 17-03-2016, 21:44
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: US Digital Shaft Encoder and VersaChassis Hex Shaft
We turn down the end of our hex shaft to 1/4'' and link the two with surgical tubing and zipties (which work much better and are more robust than any other sort of connection we've tried).
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 17-03-2016, 21:48
FRC #2489
What do you mean by turn down the end of your hex shaft?
Unread 17-03-2016, 21:51
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
They used a lathe to reduce the diameter of the shaft.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 17-03-2016, 21:54
AKA: Eli Barnett
To "turn" something in this context means to machine it on a lathe.
If your team doesn't have a lathe, I strongly suggest you invest in one. Even a cheap small hobby lathe (that's what we use) can do wonders.
Unread 17-03-2016, 21:57
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Cut a slot in the shaft. Insert the encoder in the oversized hole. Put a shaft collar around it to make the slotted hole compress down on the shaft of the encoder.
Hugh
Unread 17-03-2016, 22:07
FRC #2489
We already have 0.251" hole in the VersaChassis shaft (which WCP said was designed for a 1/4" shaft encoder), but that hole is too big, and there isn't enough friction between the shaft on the encoder and the hole in the VersaChassis shaft to make the encoder shaft turn with the axle.
Unread 17-03-2016, 22:21
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
We've reamed some of our own shafts and they've came out a little big, we just put some hot glue in there and were g2g. You can do other tricks to make the hole in the shaft work.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 17-03-2016, 22:31
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
A few other options.
We have been using Ruland flexible couplings with the 1/2" shaft on one end and 1/4" shaft on the other.
You could drill and tap a hole for a #10 set screw and then use a set screw to hold the 1/4" shaft tight.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-03-2016, 22:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Hot glue works. You can also take a small pocket knife or similar tool and gouge a hefty scratch in the inside of the hole. It should raise a burr just enough to provide a little bit of friction to snugly fit the encoder shaft in there.
You could also try a little piece of scotch double sided tape on the encoder shaft, to take up some of the space.
If you were careful about it, you could probably even use an automatic spring loaded center punch to punch a dimple into the encoder shaft itself, causing it to deform outward a little bit.
I will also note, we typically would not mount encoders of this sort. It's an over-constraint. We would fit them to the shaft, and then just let them float free, placing a zip tie on the cable, just to prevent the body from rotating.
Unread 18-03-2016, 14:12
Munchskull's Avatar
Team Role: CAD
Rookie Year: 2013
I would like to add a warning about hot glue. Only use it on encoders used for speed sensing, if you need to sense position please use a set screw, press fitting or some other method that assures the shafts is locked down. I realize that the OP has specifically said it is for the drive train and thus we can concluded that these are for speed sensing. That said I personally made the mistake of applying that to a hall-effect pot which has lead to some unpleasant failures this year. I hope that no one ever makes the mistake I did.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 18-03-2016, 14:43
Treadus Treadus is offline
FRC #1987 (Broncobots)
Rookie Year: 2007
Treadus is an unknown quantity at this point
We have used hot glue to get a good fit in the VersaChassis hex shaft in the past with great results.
This year we hot glued the encoder in the shaft, but ended up breaking one of our encoders (the shaft seized up). Likely due to shock and shifting alignment on the encoder. You know, catching air over defenses and all.
To echo one of the previous suggestions, I would highly recommend using a helical beam coupling to protect the encoder from shock and so you don't have to stress out too much about alignment. Especially for this game. Since we seized up the one encoder, we've moved to using a helical beam coupling and have had no issues.
Unread 18-03-2016, 15:53
AKA: Eli Barnett
Surgical tubing and zip ties do this better and far cheaper than a beam coupling. It's one of the best solutions we've shamelessly copied from other teams.
Unread 18-03-2016, 20:02
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Team Role: Coach
Rookie Year: 2013
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Here's a picture of our solution. It's a 3D printed 1/2" hex to 1/4" D-Shaft (the one on the encoder) coupler. We also have the 3D printed mounting brackets. Probably overkill, but we haven't had any issues with the encoder seizing up throughout 12 matches this season, and countless practice hours.
http://i.imgur.com/5u2Yvzb.jpg?1
I can send you the CAD if you want.
(PS. It's the bright orange)
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
  #15   Spotlight this post!
Unread 18-03-2016, 08:42
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Could epoxy a 1/4" shaft into the hole in the shaft and the use a piece of 1/4" id hose to attach the the encoder to the drive.
