Go to Post So let me get this straight. We'll have 6 hours to re-build an entirely new robot that took us 6 weeks originally to make. - [more]
Unread 19-03-2016, 12:35
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
USB camera using java that doesn't use too much bandwidth
We have followed the Follow the steps shown here: http://wpilib.screenstepslive.com/s/...ifecam-hd-3000
We followed the java in the SimpleVision example.
We have a working USB camera for our driver to see only (no vision tracking)
but when we are at competition the image freezes.
How can we dial down the bandwidth consumption for a simple USB camera that works in competition?
Assume we know nothing. We are a low budget team that builds in the teachers lounge.
Thanks in advance for your help.
Unread 28-03-2016, 12:08
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
Rookie Year: 2014
soundfx is an unknown quantity at this point
Re: USB camera using java that doesn't use too much bandwidth
In the code, set the size and quality to lower values. Our team uses 320x240 size and it provides clear enough vision for drivers and does not use too much bandwidth. The quality doesn't affect anything nearly as much, but lowering that might help. You can change these either in the driver station or using the setQuality and setSize methods.
Unread 30-03-2016, 12:14
redstonedash redstonedash is offline
FRC #3218
redstonedash is an unknown quantity at this point
are you sure it is the bandwidth? your code might not update the image as much as you would like. do you know how often the cameras code is running?
