Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 20-03-2016, 22:38
brk brk is offline
FRC #0180
brk is an unknown quantity at this point
GRIP publish rate
I understand that GRIP will read a frame from the camera and pass it through a pipeline. I have two questions related to that.
If the output image of one stage is handed to two other modules like a split-Y or branch, do the two operations happen in parallel? For example, taking a resized image and sending it both to HSLThreshold as well as sending it to the driver station, will both the calculations and network write happen in parallel?
Second, is there a way to find out how often GRIP updates/publishes a contours report to NetworkTables? I see in the code that the pipeline scheduler is set to 1ms, but I believe the capture and processing take much longer than that. I'd like to know how often the values should be read/consumed by the roborio.
Unread 21-03-2016, 12:02
blackrootbot blackrootbot is offline
FRC #5489
blackrootbot is an unknown quantity at this point
Re: GRIP publish rate
I am curious about this too.
