Go to Post He told me "I guess I am still learning Mr. King." I told him "That's a good thing. So am I." - mathking [more]
Unread 22-03-2016, 08:13
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Scoring Issue
Hello,
We had a match at the Bayou Regional (qual 73) where we scored two boulders in the high goal. We lost by 3 points, but noticed in the scoring summary that we did not get credit for the two high goals.
When it was addressed to the FTA and Head Ref through a student in the question box, in the allotted time, we were told that they could not reproduce a field fault and that no person was responsible for ensuring that boulders were scored correctly.
So the boulders are scored solely by the automated counters and software. If there is an error, teams do not have a method for getting the score corrected.
I will upload cell phone video later when I get it from my student, I was hoping to have the Team Spectrum Video, but they haven't been able to upload it yet for that match.
This issue/system needs a human overseeing it to ensure teams are getting credit for their hard work.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 22-03-2016, 14:57
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Rookie Year: 2012
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: Scoring Issue
Here is proof that there was a field fault. I have video of the match and the TBA page showing there weren't any boulders scored (when there were actually 3 scored during the match)
Video: Removed, the student uploaded the wrong match. Will update.
TBA: https://www.thebluealliance.com/match/2016lake_qm73
Obviously there wasn't much we could do about the issue other than ask the Head Ref to replay the match, which he declined. Everyone, make sure that the scoring is correct after each match. Had we found out about this issue right after the match, it is possible the field could have been tested at that moment and an issue could have been found.
To those opposing video replay of matches: this is a prime example of why it is needed. Losing this match caused us to move down in the rankings by a significant amount (~5 ranks) and while it may not have affected our alliance selections that much, just think of the implications had we been top 8 at the time.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 26-03-2016, 17:09
Boltman Boltman is online now
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Scoring Issue
Refs don't count boulders and since they don't they are not responsible for changing the score in fact they may not be able to anyhow , however the field crew should have tapped the castle to make the boulder fall to be counted (if that is why it did not score) .... tough break
AS for crossings that is ref counted.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 27-03-2016, 23:34
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Re: Scoring Issue
https://www.youtube.com/watch?v=3-yT...MnI8 yp-yJU6X
Finally, here is the video. It is clear that we scored 2 high boulders and did not receive credit.
Clint Brawley
USAF 1992-2013
Unread 27-03-2016, 23:41
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Scoring Issue
Did the boulders drop into the corral?
If the answer is "No", then they are by definition NOT SCORED. (Section 3.1.4) Unfortunately, that leaves you in a lousy position.
If the answer is "Yes", then you have a Field Fault. THAT needs a determination that there WAS a Field Fault, that it affected the outcome of the match, and that someone complained, in order to do anything. (TBH, I'd suspect that the latter two are pretty straightforwards--you complained that that lost you the match. It's the first one--and convincing the proper personnel--that's the problem.)
If boulders are jammed, that's a different problem altogether, as they're supposed to be poked loose pretty quickly.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 27-03-2016, 23:42
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Scoring Issue
You are not the first who got cheated by the system. You are not the last.
It is pretty clear that those 2 boulders were not counted, even if they went in.
you should contact First directly to address your issue. There is not much else you can do at this point.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
