Go to Post You don't become great because of your sponsors, you become sponsored because of your greatness. - Bdf809 [more]
Unread 23-03-2016, 14:57
snotsdelta snotsdelta is offline
FRC #6056
snotsdelta is an unknown quantity at this point
T-Shirt Cannon
My Team has constructed a T-shirt Cannon, which got tested for the first time today. We had a very anticlimactic result has the T-shirt basically just fell out of the end of the tube. We are using the KOP pneumatic system connect to about 1.5 foot ABS tube. The tube has a inside diameter of 3". I know we do not have enough pressure behind the T-shirt. I was wondering if a smaller diameter tube would fix this issue? We have our pressure built up to 110psi, which I thought would be enough to at least get 20 yards. Any help on this would be greatly appreciated!
Unread 23-03-2016, 15:01
JR0405's Avatar
JR0405 JR0405 is offline
#StaySavage
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
Re: T-Shirt Cannon
Check to make sure there aren't any leaks and that you are releasing the air pretty quickly so there's a fast burst of air
Unread 23-03-2016, 15:04
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: T-Shirt Cannon
How are you introducing the air to the shirt? You need a fast acting valve in order to ensure the full psi is applied to the shirt in a small time frame rather than slowly over time. Look up designs online of potato guns (or other t-shirt cannons) and see what kind of valves they use. Sprinkler valves are very popular.
Unread 23-03-2016, 15:23
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: T-Shirt Cannon
The valves and tubing specified by FRC are specifically chosen to LIMIT flow rate... you want to maximize it.
When we built a t-shirt cannon we used a sprinkler valve https://www.homedepot.ca/en/home/p.1...000769546.html
Note that these valves are designed for water pressure, not air pressure. A small crack with water pressure causes a small leak. A small crack with air pressure (compressible fluid) causes an explosion.
The same thing applies to your compressed air storage tanks. Don't assume that a 200psi rating on plastic pipe makes it safe for holding 100psi of air pressure. You will likely be using some components outside their designed applications... it can be made to work (you'll see lots of people doing it on online videos and instructables), but we chose to use air-pressure rated pipe black iron pipe as our storage tank. Maybe a bit conservative... but just be aware that the same energy that goes into launching the shirt can also go into launching shrapnel if your tank or valve lets go.
Another feature to consider adding would be an IR or ultrasonic rangefinder on the tip of your cannon barrel that disables firing if an object is detected in front of the cannon barrel.
I assure you, the results will be pleasing. We had to dial back the pressure on ours because we were bouncing the shirts off the gym ceiling, rather than arcing them nicely into the stands.
Jason
Unread 23-03-2016, 15:55
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Rookie Year: 2013
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
Re: T-Shirt Cannon
What is generating the propelling force isn't just the pressure, but a combination of pressure and flow. Simply put, you need enough flow to maintain a pressure behind the T-shirt as it travels down your barrel.
If you are using 1/4" tubing and a KOP solenoid to feed that giant 3" ID tube, and you imagine your T-shirt as a perfect seal against the back of the tube with negligible clearance, then yes at T=0 you have an impressive ~700 lbs of force to get that T-shirt out of the cannon. (1.5^2*pi*110psi).
Let's say the T-shirt weighs 0.25lb and just use an arbitrary delta time of 1ms.
At t1, let's make an assumption that we had enough air to sustain the force (and acceleration) on the t-shirt. F=ma/gc, so 770/(0.25/32.1) = 90000 ft/s^2. v=at, so the velocity after 1ms is 90 ft/sec. That's a pretty decent speed, about 60 miles per hour, or the speed of a decent pitch by an amateur.
So we're good to go right? We have a lot of pressure, generating a lot of force, T-shirt goes boom!
Let's go back and check an assumption though, our unlimited air flow. Assuming again the constant acceleration (which means we maintain 110psi across the entire 1ms, then x=1/2at^2. So X= 0.5*90000*0.001^2 (ft), or 0.045ft, or 0.5inches. So our T-shirt has traveled 0.5" down our barrel, so in order to maintain the pressure behind it, we need 1.5^2*pi*0.5 inches of air at 110 psi, or 3.5actual cubic inches, or 26 standard cubic inches. (110/14.7). This is 26/(12^3) or 0.015 standard cubic feet. Nice low number right? We can handle 0.015 SCF. Wait a second though, we are doing this in 1ms. So that is 0.015*1000*60, or a whopping 900 SCFM if we want to maintain the pressure behind our T-shirt as it hurtles down the barrel.
If I go to my charts, let's say our feeder tube is 0.1875" ID, 900 SCFM, 1 foot of tubing, 110psi... it tells me I'm losing 8000psi per foot. So hrm, I'm probably not getting that out of it. I have to drop down to 90SCFM just to get to where I'm losing 110psi across the 1 foot limit. If I only flow 90SCFM instead of 900, I'm only getting a 10th of the pressure behind the T-Shirt I thought I had... or something like 10psi. Now I'm not getting 60 miles per hour... I'm getting 6 miles per hour.
So really, what ends up happening is your T-Shirt moves along the barrel at the flowrate of the tubing/valve limiting it, and plops out the front.
Long story short, my math might be a little off, I was just spitballing, but as several posters above stated, to make the system work, you need two things... storage preferably quite close to your barrel, and a large valve capable of providing high flow rate. You could potentially run it all off of a KOP compressor, but you might only get to take a shot every few minutes (do the math), and run it at near 100% duty cycle (which it isn't designed for).
As always, please be careful. It's easy to think that 110 psi isn't a big deal as it is "shop air", but you are harassing a lot of energy. If you try to trap that pressure of air in many containers (plastic), you can blow something up. Many types of plastic turn into shrapnel when they explode, which can seriously injure or kill someone. The preference is to use more ductile metal pipe where available (which won't turn into shrapnel), or at the minimum encase any plastic parts in a shield and don't work on it under pressure.
2013 - 2016 - Mentor - Robochargers 3005
2014 - 2016 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 23-03-2016, 16:33
SamM SamM is offline
FRC #5842 (Royal Robotics)
Team Role: Teacher
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Re: T-Shirt Cannon
We use one of these valves on our cannon:
http://www.electricsolenoidvalves.co...olenoid-valve/
A little bit more expensive than the sprinkler valves, but it's rated for air pressure.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 23-03-2016, 16:44
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: T-Shirt Cannon
Beside what is posted above 3" is to big. I think we use 1.5" or 2". It works great.
-Hugh
Unread 23-03-2016, 17:09
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: T-Shirt Cannon
I wish I had found that one when my team was making our t-shirt cannon. We used a fairly similar valve, only 3 times the price.
http://valvesandinstruments.com/sole...l-service.html
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 23-03-2016, 17:19
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
Re: T-Shirt Cannon
this may seem stupid but how are you folding the shirts? if you just sort of shove them in the barrel it will open in flight like a parachute. However, there is a way to fold a $@#$@#$@#$@# to make it more rigid, if folded this way you can toss it, throw it, or shoot it and it will stay together. (PS, working on pics)
"The difficult we do today, the Impossible tomorrow, Miracles by appointment only."
"Theory is a nice place, I'd like to go there one day, I hear everything works there."
"Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot."
"I have approximate knowledge of many things."
Unread 08-04-2016, 14:56
FRC #6056
Re: T-Shirt Cannon
When we wired it to our PCM we keep getting a solenoid fault on it. We changed our program to a single solenoid as we were using a double. Just wondering if we had to do something different wiring wise as there is no errors in our program
Thanks!
Unread 08-04-2016, 15:07
Team Role: Teacher
Re: T-Shirt Cannon
The PCM may not be able to supply enough current for the larger solenoid. You may need to use a victor or another speed controller to supply power to it, which is what we did. You could also probably use a small automotive relay.
Unread 08-04-2016, 15:20
FRC #6056
Re: T-Shirt Cannon
Great Thank you! So then we will wire the solenoid though the Victor to the PDP then correct? Thanks again!
Unread 08-04-2016, 15:33
Team Role: Teacher
Re: T-Shirt Cannon
Yes, just treat it as a motor and run it at full power when you want it to open and no power when you want it closed.
Unread 08-04-2016, 19:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: T-Shirt Cannon
We switch the solenoid valves on our air cannon with a 12 relay module similar to this one. Our first iteration used a spike relay, with one valve powered by M+ and the other by M-, with a common 0V (ground) return.
  #15   Spotlight this post!
Unread 23-03-2016, 18:14
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: T-Shirt Cannon
I'll save my lecture about using plastic as a barrel for a later thread.
Your pressure is not the issue. 110PSI is overkill. What your issue is ... is flow and reserve air.
Gas (in this case, air) expands to fill the area (universal gas law). It only takes a few pounds of force to overcome the friction if the t-shirt to the barrel. Once that happens the t-shirt begins to move up the barrel, increasing the volume that the air needs to fill and dropping the pressure in the barrel. You need a flow rate that is higher than the expected volume increase as the t-shirt moves up the barrel and enough of an air reserve to sustain that flow rate throughout the entire firing time.
If you don't have enough air flow, or enough reserve air to fill the entire barrel at the pressure you want, the t-shirt will not fire very far ... and will tent to just drop out of the barrel rather than fire out.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
