Go to Post We appreciate the time/effort of everyone who contributes to Chief Delphi... hopefully, someday soon we'll be experienced/seasoned enough to contribute advice ourselves... - Michael Blake [more]
Unread 23-03-2016, 19:30
marshmello marshmello is offline
FRC #1711 (The Raptors)
Team Role: Mechanical
Rookie Year: 2015
marshmello is an unknown quantity at this point
Retraction issues, because we're lazy.
Our team is getting just a little bit sick of booting up the robot before every single match just to pull in our shooter, so we're within frame perimeter to start matches. The other day, I heard one of the mentors mention in passing some kind of arduino-based system that would power the necessary electronics and motors, without powering the robot and the whole comms system. This is sounding better and better as we start working on a lift system for our second regional, seeing as we'd rather not deal with 7 feet of flying tape measure trying to get the robot off of the field. Call me lazy.
So, have any other teams done this? Any ideas on legality/practicality? It would be a huge help, but if it's not more helpful than it is complicated, I can probably suck it up and just keep the driver station up and ready between matches.
Unread 23-03-2016, 20:15
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Retraction issues, because we're lazy.
Like something somewhat akin to a PWM Signal Generator? I suppose it would get the job done, though going this route would require remembering to always rewire the robot correctly each time you want to jack into it.
I think it's far simpler to just boot up the driver station between matches and connect via ethernet, seeing as you'll have to do so anyways should you want to change the robot code.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 23-03-2016, 20:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you want to use a separate control system, you would have to have a way to switch out the legal one and switch in the "simple" one. That sounds like a lot of trouble, and unless you had a huge many-pole switch it would probably take longer to change between them than to just boot the roboRIO. But I don't think I understand the problem. Is your robot out of starting configuration when you leave the pit?
As for having to retract stuff at the end of a match, one solution I have seen is to have a mechanical connection to the motor shaft that can be driven by an external crank or cordless electric drill.
Unread 23-03-2016, 20:58
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
As I believe the other two said, this board that you are using may in no way be used at any time during inspection or when the robot is in normal operation as you may not control motors from any other source than the roboRIO.
Another option (albeit not the first one I would recommend if you can find a better one) is to hook up a spare Anderson connector (one that you'd screw onto a battery) with some crimps on the end of it so you just disconnect the motor -> plug it in the battery (preferably middlemanned with some signal modulator so you dont overdrive the motor) and move it down like that.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 23-03-2016, 21:00
DonRotolo's Avatar
Back to humble
FRC #0832
I was wondering the same thing.
Unread 23-03-2016, 21:01
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
We used a similar system at palmetto thus year. We used the guts of a cordless drill and connected our arm pivot motor to it (variable speed trigger on the drill). During one of our Elim matches, we were told it was not legal to use. I can't remember specifics however it was because of a similar ruling as with off board compressors.
The motor was not being controlled 1) by the robots power supply for that match (simple fix, use the battery currently on the bot) and 2) the signal controlling the motor did not originate at the roborio.
So assuming this follows over to other tournaments, the only legal course of action in my opinion then is powering up and connecting to the roborio.
Unread 24-03-2016, 11:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
If you're saying this motor power system was completely off-board and only connected outside of a match.... I don't think that's correct and I'd want a Q&A on it. The rules only require that a robot be legal and inspected when placed on the field for a match. It doesn't have to be legal in your pits or in queue or something. The off-board compressor rules are probably the only exception to that for safety and fairness reasons.
G10 does state that you can't tether to the robot after a match, and tether is defined as any wired or wireless connection to control or energize part of the robot. So your drill guts wouldn't be legal for driving a mechanism before you get off the field.
Unread 24-03-2016, 14:04
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
In 2015 G9 specifically allowed powered drills to reconfigure your robot on the field. No similar rule in this years manual. You know what they say about last years rules.
If you don't know what you should hook up then you should read a data sheet
Unread 27-03-2016, 08:58
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
We have, in the past, used SAE connectors on all our motors to allow quick swapping out in the event of a failure. They (or other appropriately sized connectors like small Anderson connectors) also allowed us to easily power the motors externally for testing or pre-match positioning.
Older, but still somewhat coherent.
