Go to Post He told me "I guess I am still learning Mr. King." I told him "That's a good thing. So am I." - mathking [more]
Unread 26-03-2016, 12:45
IbrahimE. IbrahimE. is offline
FRC #5416
IbrahimE. is an unknown quantity at this point
Sally Port Rules
My team, TARDIS robotics, was wondering about the legality of some of the things we want to do.
if we or any other team holds the door open and let the other 2 robots in , Does the door need to close before letting a second robot in?
Is there a rule against having robot A hold the door to let robot B in and then Robot B holds the door on the other side to let Robot A in?
Unread 26-03-2016, 12:46
GaryVoshol's Avatar
Happy Birthday! GaryVoshol GaryVoshol is offline
Cogito ergo arbitro
Rookie Year: 2000
Re: Sally Port Rules
No and no
(since 2004)
Unread 26-03-2016, 13:56
Dibit1010 Dibit1010 is offline
FRC #0587
Dibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond repute
Both are legal and have been done
Unread 26-03-2016, 16:52
M217's Avatar
M217 M217 is offline
#TSIMFD
AKA: Muhammad Mousa
FRC #3419 (Rohawks)
Team Role: Tactician
Rookie Year: 2014
M217 is on a distinguished road
Yeah, no specific rules against them. However, it might be overkill to have to "chain-cross" the SP since it slows down the breaching of other defenses -- it counts as a legal cross if you just travel back through the door from the courtyard, which any robot can do, and then spin in place, losing contact with the flap, before driving through again. Having one robot do this twice is typically faster than trying to coordinate a 3-bot chain and it frees up your alliance partners for scoring.
Unread 26-03-2016, 16:58
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Having one robot open the door and 2 going through can be quite fast with good drivers. Use the least capable bot to open the door. You only have to do it once.
If you don't know what you should hook up then you should read a data sheet
Unread 26-03-2016, 17:05
Billfred's Avatar
Billfred Billfred is online now
And if you can't judge off that, pick by the slickest bumpers or smallest frame. There will probably be some rubbing unless you prop that sucker wide.
Unread 29-03-2016, 18:06
BethMo BethMo is offline
FRC #0948 (NRG (Newport Robotics Group))
BethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to beholdBethMo is a splendid one to behold
Originally Posted by M217 View Post
... it counts as a legal cross if you just travel back through the door from the courtyard, which any robot can do, and then spin in place, losing contact with the flap, before driving through again.
Since the door opens in the direction that blocks the outerworks referee's view of the robot, it can be very difficult to tell whether the robot lost contact with the flap or not. It can sometimes even be difficult to tell whether the robot got entirely off the ramp from the defense! If the referee is not sure whether the robot did both of these things, then they're not supposed to give credit for the cross. That makes this a risky strategy.
For the best chance of getting it counted, drive far enough past the door that half of your robot is visible to the referee. It also helps if you can get the door to visibly bounce off your robot, breaking contact more than once.
Unread 29-03-2016, 18:11
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Or, just have a robot on your alliance that can open it from the neutral zone.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 29-03-2016, 18:34
BigJ BigJ is online now
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
You have to get a feel for the ref staff at your regional/division. At the St Louis regional the refs seemed very hard-set on a very visible "swing away", where at Wisconsin the refs seemed to give credit as long as you did a reasonably fast spin in the neutral zone. The second interpretation makes more sense to me since a rectangle robot would have to turn pretty slow to not at least momentarily break contact, but I can see it both ways.
Unread 29-03-2016, 19:32
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
At the two regionals I have attended and competed in (Finger Lakes and Pittsburgh) the ref(s) watching the defenses would give a very visible ok such as a head nod or thumbs up if contact was lost and the cross would count. On the contrary, if the cross would not count they would give a very visible no good.
We also noticed that as long as the robot was off the ramp and did a 180 or 360 degree spin the cross was always counted.
