Go to Post Success is making a difference. - SlamminSammy [more]
Unread 28-03-2016, 19:41
HatterTingamaji's Avatar
HatterTingamaji HatterTingamaji is offline
AKA: Liberty Forrest-Okey
FRC #4277 (Thingamajjigers)
Rookie Year: 2015
HatterTingamaji is an unknown quantity at this point
Question Autonomous Problems / I'm dumb
Ok so I'm trying to get Autonomous up and running and forgot what I would use to convert from Int to Boolean,
if you can even do that.
I'm not even sure anymore.
Unread 28-03-2016, 19:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Autonomous Problems / I'm dumb
While there are casts, the best (most readable and consistent across languages) way to convert a number to Boolean is to us a comparison operator. For example, if you want false when x is zero and true otherwise, use (x!=0).
Edit: that's ok with integers. With floats, you have to watch out for NaN cases. My favorite way to test around all of the cases where x is not a number is to do something like (x==x && x!=0).
Unread 28-03-2016, 19:55
Rookie Year: 2015
Ok so I'm not crazy (well no more so than usual). Thank you!
Unread 28-03-2016, 22:05
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
These exist for a reason!
Code:
Double.isNaN(double)
Double.isInfinite(double)
Unread 29-03-2016, 06:35
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Calling two negatively phrased language-dependent methods is better than one comparison? If there were an isFinite() method, I would consider using it.
Unread 29-03-2016, 09:31
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Better than using x==x, which seems hacky and is surely platform/implementation dependent. It's better not to introduce hard-to-diagnose bugs in your code.
