Go to Post Really heavy snow is different in Minnasota and Oklahoma... It has to be pretty bad up there. - thatoneguy23 [more]
Unread 29-03-2016, 07:55
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Operator
Rookie Year: 2014
whitetail is an unknown quantity at this point
Cameras on poles for viewing the field
My team is going to try putting a camera on a pole for our next competition. We have most of the materials needed but we have a few questions.
1) What screen do you prefer to you display the image?
2) What brand of extension cord do you use for the usb camera?
3) How long does it take you to set up before each match?
Anything else that you could add would be helpful.
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590, 2607)
Unread 29-03-2016, 08:05
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is online now
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
Re: Cameras on poles for viewing the field
1.) we have the webcam viewer open on our driver station laptop open above the driver station and next to the smart dashboard
2.) Amazon basics 9ft USB extender
3.) Takes us about 45 sec to comepletly set it up. We have plenty of time to set it up.
4.) Make sure you follow the new updates to camera poles such as making sure it is not taller than 11'8" which is the height of the tower flags and also make sure you are not clamping it to the driver station shelf. We got around this by attaching a large pvc pole to our operator console where the camera pole just slides right over it.
As far as the pole we used, we used an extendable pool skimmer pole which allows for easy transport as it is collapsible but also allows for easy modification to make it shorter on the field if a ref deems ours too tall.
Unread 29-03-2016, 09:12
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We used a SJCam SJ4000 velcroed and tie wrapped to the end of a window washing pole from Home Depot. The base of the pole, with the handle removed, fits exactly in a Sch. 40 PVC pipe, that we attached to the operator console with a threaded fitting attached to a cast iron flanged base. It's a three section pole and I think it has a total reach of 9', which is plenty to get the camera to the maximum height. There's 8" of PVC pipe.
An 8' Micro HDMI to HDMI cable runs from the camera to a 23" display.
Here's a good photo of the lower part of the pole unit: https://onedrive.live.com/redir?resi...nt=photo%2cjpg
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 29-03-2016, 09:51
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
We are still developing our pole but we have a painters pole that we are attaching a GoPro to, then running a micro HDMI to HDMI cable (roughly 10ft) to a monitor. We are still figuring out what size to use but it will either be a 22" or 32" at this point. We are still figuring out the mounting system but we should have it ready by next weekend.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 29-03-2016, 10:25
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Make sure it remains below 11'8" from the floor and is attached securely to your driver station. As it is part of the driver station it must comply with driver station rules and be within the 14" x 60" size limit.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 29-03-2016, 10:30
JR0405's Avatar
JR0405 JR0405 is offline
#StaySavage
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
At CIR there was a team using a patio umbrella stand to hold there pole and I thought it was a good idea and was probably pretty stable
Unread 29-03-2016, 10:41
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I highly recommend one of these:
http://www.homedepot.com/p/Fiskars-1...966J/100153111
Also, we used a go pro with a 27" hdmi screen, and absolutely loved the quality.
We had better luck with the go pro hero 4 than the hero 3+ being better quality when streaming from the camera directly to the screen.
Unread 29-03-2016, 11:14
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
Rookie Year: 2013
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Is having a camera still worth it at 11' 8"? Does anyone have a picture of what the field looks like at that height? Thanks!
Unread 29-03-2016, 11:20
Calm Cool Collected
FRC #1126 (SparX)
Rookie Year: 2015
I don't have a picture of what the field looks like from he pole but from expierence of being on the field and using it I would say it is definitely worth it. It's not something you will necessarily be using all match every match but it is definitely useful in certain situations such as trying to go over the drawbridge when you can't see your robot or alignment on a goal
Unread 31-03-2016, 01:03
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Rookie Year: 2014
Eryl2000 is an unknown quantity at this point
We had a camera pole at the District event we attended last week and it was extremely helpful. The height limit, created by the GDC due to safety concerns, was still plenty high for the pole to be useful in almost all situations. As the coach, I found myself almost constantly watching the camera pole monitor. In fact, I may have watched the monitor more than our actual robot!
Unread 31-03-2016, 08:54
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
2067 Apple Pi has posted two videos of the field taken from the GoPro on top of the pole:
http://www.youtube.com/watch?v=3-Lj4L4g1o4
http://www.youtube.com/watch?v=da9zwSaKZmw
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 31-03-2016, 00:59
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I looked at a few different poles at Home Depot when we built our setup, the painters poles and tree trimmer poles were ridged but overkill in my opinion (plus heavy, making it harder to hold up), eventually I came across these.
They come in like 3 different sizes (got this one before the rule change, in retrospect we could have gotten a smaller one), but they're great because they're very light, compact, and are more than ridged enough to support a small camera. We used a PVC DWV Closet Flange adapted down to short 1-1/4" PVC pipe that fits the pole nicely and mounts to the driver station with strong Velcro.
As for the camera, we just use a Logitech C920 Pro Webcam with a 6ft usb extension into our 17" laptop (we also have a small 7" HDMI screen that can be used do display either the camera or dashboard as a second monitor).
Unread 29-03-2016, 11:25
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Rookie Year: 2011
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
That may not be a great idea. There was a team using, or trying to use, a patio umbrella base that weighed at least 40 pounds. It was heavy enough that it was causing the drivers station shelf to slope quite a bit under its weight.
While a wide base is probably a good idea, a 40 pound chunk of steel that could fall on your feet is likely to be called a safety hazard.
Unread 29-03-2016, 15:09
ejscribner ejscribner is offline
Drive Team & Coach
FRC #2972
Rookie Year: 2013
ejscribner is an unknown quantity at this point
We ended up welding a piece of pipe onto our driver station so we could just drop the pole into the driver station while setting up
  #15   Spotlight this post!
Unread 30-03-2016, 16:31
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Rookie Year: 2000
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Here is what we use. Very quick and secure.
success is not hocus posus, it's focus focus
