Go to Post The short answer is there is no shortcut. - JDNovak [more]
  #16   Spotlight this post!
Unread 31-03-2016, 00:03
JR0405's Avatar
JR0405 JR0405 is online now
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Cameras on poles for viewing the field
Originally Posted by DareDad View Post
That may not be a great idea. There was a team using, or trying to use, a patio umbrella base that weighed at least 40 pounds. It was heavy enough that it was causing the drivers station shelf to slope quite a bit under its weight.
While a wide base is probably a good idea, a 40 pound chunk of steel that could fall on your feet is likely to be called a safety hazard.
Your correct however their base was fairly small but big ones might cause an issue
  #17   Spotlight this post!
Unread 31-03-2016, 00:59
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by Cash4587 View Post
I highly recommend one of these:
http://www.homedepot.com/p/Fiskars-1...966J/100153111
Also, we used a go pro with a 27" hdmi screen, and absolutely loved the quality.
We had better luck with the go pro hero 4 than the hero 3+ being better quality when streaming from the camera directly to the screen.
I looked at a few different poles at Home Depot when we built our setup, the painters poles and tree trimmer poles were ridged but overkill in my opinion (plus heavy, making it harder to hold up), eventually I came across these.
They come in like 3 different sizes (got this one before the rule change, in retrospect we could have gotten a smaller one), but they're great because they're very light, compact, and are more than ridged enough to support a small camera. We used a PVC DWV Closet Flange adapted down to short 1-1/4" PVC pipe that fits the pole nicely and mounts to the driver station with strong Velcro.
As for the camera, we just use a Logitech C920 Pro Webcam with a 6ft usb extension into our 17" laptop (we also have a small 7" HDMI screen that can be used do display either the camera or dashboard as a second monitor).
  #18   Spotlight this post!
Unread 31-03-2016, 01:03
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Rookie Year: 2014
Eryl2000 is an unknown quantity at this point
We had a camera pole at the District event we attended last week and it was extremely helpful. The height limit, created by the GDC due to safety concerns, was still plenty high for the pole to be useful in almost all situations. As the coach, I found myself almost constantly watching the camera pole monitor. In fact, I may have watched the monitor more than our actual robot!
  #19   Spotlight this post!
Unread 31-03-2016, 08:54
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Originally Posted by team-4480 View Post
Is having a camera still worth it at 11' 8"? Does anyone have a picture of what the field looks like at that height? Thanks!
2067 Apple Pi has posted two videos of the field taken from the GoPro on top of the pole:
http://www.youtube.com/watch?v=3-Lj4L4g1o4
http://www.youtube.com/watch?v=da9zwSaKZmw
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
