Go to Post Cue all the jokes about natural selection in the Darwin division - TDav540 [more]
Unread 29-03-2016, 12:43
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Labview autonomous programming via excel/csv file examples
Dear CD,
I am presently using 4 difference autonomous programs that could be easily made into one program if I was able to use some kind of input file that would change motor power levels and pneumatic solenoid on/off enabling as a function of time. I think some kind of excel/csv file with 0.1 second intervals of time as rows and columns containing the motor 1-6 values and 2 pneumatics solenoids as on/off are what I need. I am sure that this has been done by others and would appreciate any links to such material.
Best regards,
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 29-03-2016, 14:33
Greg McKaskle Greg McKaskle is online now
Re: Labview autonomous programming via excel/csv file examples
The default auto has some commented code that executes across an array of motor values, times to delay, etc. The file I/O palette contains many options for reading the file. The second icon is a bit confusing because of how general it is, but it defaults to return either a 1D or 2D array of doubles from a tab delimited file.
Then next step is to get the file on the roboRIO.
A variation of this is to load the file on the DS laptop using a custom dashboard, and push the values to the robot using some network table variables such as arrays of doubles.
Greg McKaskle
Unread 29-03-2016, 15:32
marccenter's Avatar
Team Role: Coach
Greg,
Thanks for the information. I did some searching and found a paper by Chris Hibner that appears to be the direction I want to move in for the short term.
I will let you know how that goes as team 3548 gets ready to go to the Michigan State Champtionship in Grand Rapids, MI this year!
Best regards!
Marc Center
