Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Unread 29-03-2016, 22:14
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Rookie Year: 2013
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
Re: Antenna design
I think it's important to go with something pivoted front/back or that can't bend sideways like those lexan strips, other wise you risk them bending sideways out of the 15". Also having 2 colors front/back or side to side so the driver will know the orientation of the robot.
Because the Lexan strips we (3005) use have 0.125" thickness in the front/back orientation and ~2" in the side to side, they have a fairly large resistance to bending in the side-to-side direction, while folding over easily in the forward/back.
If you were to grab one and forcibly twist it while pulling sideways, you might be able to get it outside of 15", but they don't interact with the defenses that way, nor do they have enough weight to do so on their own.
2013 - 2016 - Mentor - Robochargers 3005
2014 - 2016 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: Antenna design
Originally Posted by DRH2o View Post
We used Orange Fiberglas arrows ($3.00 each at Dick's Sporting Goods) with two different color fletchings. We cut the points off and epoxied to door stop springs ($1.50 for two at Lowe's). They work great!!
Here's some photos we snapped of 1598's flag implementation at VADOS. Looks great to us!
2363's flag solution really suffered when it got battered by the low bar. At our most recent event (VAPOR), about 14% of all our recorded pit activity went towards flag maintenance/repair, mostly in <5 person*minute chunks. Our drivers really liked having them though.
ID:	20471  Click image for larger version
Unread 30-03-2016, 10:06
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Antenna design
Originally Posted by kevin.li.rit View Post
I suggested we get a bunch of fans and hook it up to a speed controller and get a inflatable tube man. Unfortunately my idea was shot down
https://youtu.be/cvaRGiMWRaE
The students wanted to go with this idea for a while so we could deflate when going under the low bar and such. After a bit of prototyping and a fried/melted hair-dryer they decided it wasn't feasible on an FRC bot.
Unread 30-03-2016, 15:09
mrwright's Avatar
mrwright mrwright is offline
Coach
AKA: Michael Wright
FRC #4522 (Team SCREAM)
Team Role: Coach
Rookie Year: 2013
mrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to behold
Re: Antenna design
We have had a lot of requests on our flag design. We call them our "ding-a-lings"
We definitely got a kick out of it when the game announcer started calling them by their names as well.
Overall they are pretty simple.
We bought ATV flags from this site:
http://aditudegear.com/flags
We also bought a spring mount like this:
http://www.amazon.com/Wheeler-Whip-S.../dp/B005HJL94A
The spring mount was far too rigid so we went to Lowes and bought another spring and custom turned a plug to press fit it in the spring that was better suited for us. It is the same exact concept as the one I referenced above.
We then mounted this spring base to an angle bracket on the side of our poly-carbonate shields. You can kind of see the mounting application on the picture that the OP provided.
They work great for us and we love the visibility that they provide. They also help us square up on the defenses better because we can see them over the tall defenses.
Hopefully this helps!
Unread 30-03-2016, 16:43
Rookie Year: 2013
Re: Antenna design
Glad it isn't just us... we call ours wigglydoodads. We could not get the game announcer to do so at either regional event... so really holding out for champs!
Unread 29-03-2016, 18:13
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Antenna design
Originally Posted by FarmerJohn View Post
What are these for?
Helps you to pick out where your robot is past defenses like the Sally Port.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 30-03-2016, 09:04
Cr1spyBacon8r Cr1spyBacon8r is offline
FRC #5203
Cr1spyBacon8r is an unknown quantity at this point
Re: Antenna design
I saw one team with long zip ties with small colored flags from duct tape
Unread 30-03-2016, 09:33
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Re: Antenna design
Our is 1/2" ID 3/4" OD Nylon tube that encase LEDs. LEDs, where not used at our 1st competition but will be used next week in Minneapolis.
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
