Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 29-03-2016, 15:10
quillford quillford is offline
FRC #5924
Rookie Year: 2015
quillford is an unknown quantity at this point
Boulder inconsistency issue
Throughout most of build season we tested with only one boulder and tuned everything based off that one boulder, but as soon as we got a new one we noticed that it shot completely differently. We resolved to simply be a low goal shooter for our first regional, but now I want to look at the high goal again. I was thinking of increasing the compression (we're at 1.5" IIRC), but we were using bags for most of our testing and more compression would stall the motors on intake. Since switching to 775pros, we have not tried more compression. Does anyone have any other suggestions?
Unread 29-03-2016, 15:12
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: Boulder inconsistency issue
Gearbox? I think we're running 30:1s (don't quote me on that) on single bag motors with a ton of compression and we have no pickup issues at all
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 29-03-2016, 15:18
FRC #5924
Rookie Year: 2015
We're running them with versaplanetaries 1:1 just for the ease of mounting. Are you shooting in the high goal with that much reduction?
Unread 29-03-2016, 15:34
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Just for reference, two 775Pros at 3:1 reduction is more than enough to make high goal shots. Tuning your compression, ball feeding, and geometry is often the harder problem. A lot of teams are doing well with 3 inches of compression.
Unread 29-03-2016, 16:16
FRC #5924
Rookie Year: 2015
I don't think we have any 3:1 stages. Would a 775pro with a CIM-ile on each side work?
Unread 29-03-2016, 16:23
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Try it. Welcome to prototyping.
Unread 29-03-2016, 16:44
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
We had some luck using mini CIMs. I think you'll have the ball inconsistence issue regard less of which motor you're using. I know a used ball have a different trajectory compare to a brand new ball. I think you really need to take some time to find the sweet spot for your shooter. Don't go for the long shot. Dial in your shot at the base of the castle, that should give you a few more points per cycle. Good luck prototyping and enjoy the process.
Unread 29-03-2016, 20:01
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Thats what 4592 is running. we found 2 inches of compression was enough to shoot high goals from the low bar although I would not be surprised if 3-4 inches of compression would be more ideal. We currently run 3 4x7/8 colson wheels per side at 3370 RPM for most ranges. Also, the mechanism pushing the ball into the shooter wheels had a large effect on accuracy. Switching from pushing the ball by hand to a pneumatic indexer altered our RPM by about 200 to get the same shot.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 29-03-2016, 21:42
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
there's still time to join #TeamPneumatapult
Unread 29-03-2016, 21:47
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
#TeamPneumatapult for life.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 29-03-2016, 22:41
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
Team Role: Mechanical
Rookie Year: 2010
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
#SpringPunchers for the win!
It isn't shiny enough.
Unread 30-03-2016, 00:19
FRC #5924
Rookie Year: 2015
Do you have a picture?
Unread 30-03-2016, 00:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
The short version:
If you look at a wheeled shooter as a simple ideal system, the only things that really come into play are:
1. Shooter moment of inertia.
2. Normal force on the ball.
3. Shooter wrap.
The first matters because the ball is generally in contact with the wheels for such a short period that the motor and control system really can't react to it. By the time your system sees a decrease in velocity and tries to account for it by increasing motor power, the ball is gone. That's why some teams use heavy shooter wheels or add flywheels.
The second item matters because the only thing that moves the ball is the wheel-to-ball friction. As the balls get more used, they become much softer. This decreases normal force on the ball, and decreases the friction force that moves the ball. You need to have enough force on the ball that the ball surface speed matches the wheel speed before it leaves the shooter. I.e. - wheel slip on the ball is bad because it will result in inconsistent distances. This was an important lesson that came out of 2012.
Shooter wrap matters because the longer the ball is in contact with the wheels, the more time it has to accelerate to the same speed as the wheels. 60 degrees versus 120 degrees may not seem like much visibly, but it is substantially more time that the wheels have to accelerate the ball so they arrive at the same speed. This was a lesson we learned from 2013. In-line small wheel shooters needed multiple wheels to match what a wrap-around single wheel shooter could do. This was actually a combination of all 3 of the issues listed above, but testing proved that wrap greatly helped on the slippery frisbee surface.
Use your old ball, and tune your shooter. Then put a new ball through it. The new ball will fly much further because it will be less squishy and have more normal force (more friction). Start increasing your compression. Eventually you will reach the cross-over point where the two are shooting the same.
Of course - there are a couple additional points. It takes some brute force to do this. Either a high initial RPM, a flywheel, shooter power, or all three. Consistently introducing the ball to the shooter in the same place each time is important.
Unread 30-03-2016, 01:27
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #3663 (CPR)
Team Role: Driver
Rookie Year: 2013
zinthorne will become famous soon enough
Our shooter sees little to none or no variation between brand new and used balls. All shoot just as easily and are very accurate. The consistent shot has made our robot very competitive. The ball will alsways go in the same place 97% of the time and even when it does very it's only off by a few inches at most. We are using 2 775 pros for our shooter with 2 sets of 4 inch wheels. We are likely adding another 775 pro to aid in intake and make spin up time faster.
  #15   Spotlight this post!
Unread 30-03-2016, 05:06
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
We ran into a similar issue. The boulders on the field were significantly firmer than the ones we got in the KOP even before they were used.
Our shooter's holding mechanism relies on compression and stall torque. The main flywheels create such a strong vacuum when they spin up that they physically suck the boulder out the intake unless we run the intake in reverse, stalling the motor to hold the boulder in place. Because the boulders were much, much firmer, the MiniCIM direct couple that is our intake was not strong enough to hold the boulder in place, causing the shots to fire prematurely before the wheels got up to speed, resulting in poor shots.
In our case, it was a fairly easy fix. We adjusted the spacing on the intake's wheels to be further out, reaching further on the circumference of the boulder and therefore not causing as much compression, allowing us to stall the boulder into place. Image for reference
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
