Go to Post Sweeeetttt.....Thats all that needs to be said. :D - george56 [more]
Unread 29-03-2016, 21:43
Jeringo Jeringo is offline
FRC #4749
Jeringo is an unknown quantity at this point
TalonSRX encoder confusion java
I am getting a little confused on encoders for the TalonSRX.
i am trying to do three things, first thing is the software limit. How exactly does it work. we have a shooter that tilts the upmost position it -1000 and all the way to the floor is 3500 i've tried swapping the values but it only lets me tilt the shooter down. the second thing is how to i reset the encoder or set it to 0? and the third thing is how to i tell the motor to go to a certain position?
Code:
Tilt.setFeedbackDevice(FeedbackDevice.AnalogEncoder);
Tilt.setForwardSoftLimit(-1000.00);
Tilt.enableForwardSoftLimit(true);
Tilt.setReverseSoftLimit(3501.00);
Tilt.enableReverseSoftLimit(true);
int pulseWidthPos = Tilt.getPulseWidthPosition();
int pulseWidthUs = Tilt.getPulseWidthRiseToFallUs();
int PeriodUs = Tilt.getPulseWidthRiseToRiseUs();
int pulseWidthVel = Tilt.getPulseWidthVelocity();
FeedbackDeviceStatus sensorStatus = Tilt.isSensorPresent(FeedbackDevice.CtreMagEncoder_Absolute);
boolean sensorPluggedIn = (FeedbackDeviceStatus.FeedbackStatusPresent == sensorStatus);
Unread 29-03-2016, 22:25
GRSICP GRSICP is offline
Greta Rauch
FRC #5822 (WolfByte)
Rookie Year: 2010
GRSICP is an unknown quantity at this point
Re: TalonSRX encoder confusion java
I don't know the answer to the questions about the limits as I have not used them yet. However, I can help with getting the Talon to a certain position.
Here is an example of initialization of a Talon:
Code:
armR = new CANTalon(1);
armR.setFeedbackDevice(FeedbackDevice.QuadEncoder); //Set the feedback device that is hooked up to the talon
armR.setPID(0.2, 0.001, 100, 0.00, 360, 12, 0); //Set the PID constants (p, i, d), you will need to do some tweaking to get these right
Here is the code needed to get the arm to a certain location:
Code:
armR.changeControlMode(TalonControlMode.Position); //Change control mode of talon, default is PercentVbus (-1.0 to 1.0)
armR.set(height); //height is the value you are looking to move to
armR.reverseSensor(true);
armR.enableControl(); //Enable PID control on the talon
A note on the reverse sensor line: in our case, the reading from the QuadEncoder was negative so we needed to both feed .set a negative value and use the reverseSensor method.
In terms of setting it to 0, here is the code we use:
Code:
talonName.setPosition(0);
I hope this helps!
Unread 29-03-2016, 23:05
FRC #4749
Code:
Code:
Code:
I hope this helps!
how could i use a joystick for this?
Unread 30-03-2016, 08:55
Camilo86's Avatar
Camilo86 Camilo86 is offline
AKA: camilo
FRC #0125 (Nutrons)
Rookie Year: 2012
Camilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of lightCamilo86 is a glorious beacon of light
You can make a variable to hold your arm distance setPoint, and add/subtract from this value using the joystick's output value. Notice that joysticks have a range of -1 to 1, so you might have to multiply some constant > 1 to your joystick output so that your joystick can have a fast effect on the setpoint. This will all the depend on the distancePerPulse you currently have.
Hopper finalist 2015
Dean's List winner 2015
Unread 30-03-2016, 11:20
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Jerigo,
Have you tried looking at the Talon SRX Software Reference Manual? See the manufacturer's website.
Unread 30-03-2016, 14:20
Greta Rauch
Rookie Year: 2010
Originally Posted by ozrien View Post
Jerigo,
Here is the link:
https://www.ctr-electronics.com/Talo...e%20Manual.pdf
