Re: The REAL chokehold of 2016
I'll accept Zebracorn Cheesecake without further comment but don't be hatin' on Chicago Style Pizza or I'm come after you. Chicago Style Pizza is not just a thing, it is a thing near and dear to my heart. Dr. Joe J. |
Chicago style pizza is so deep and rich, you could sink a harpoon in it!
Would the attached robot be legal?
The frame parimeter is <120" and every external corner of the frame perimeter has at least 8" of bumper protecting it. Seems like it would be legal to me. I can see adding 4 omniwheels, a battery and the rest of the electronics and doing tolerably well in St. Louis with such a robot. You could make this from completely COTS material (some plywood, some 2 by 4s, and some deck screws and that's about it) in the pits in St. Louis in about 2 hours tops, including the bumper but you could actually make the bumper before you arrive because bumpers don't have to go into the bag... I am not saying this would be a world beater but I am saying that 20-30% of teams might do better on average with this robot than the one they currently are planning on using in St. Louis. An interesting thought experiment on a sort of Zebracorn Self Cheesecaking concept. Dr. Joe J. Last edited by Joe Johnson : 01-04-2016 at 11:05. |
The low bar and berms wouldn't be too big a problem; there's no need for the chassis to be that low to the floor. It would be best if the robot had a holonomic (or swerve) drive system so that it can drive along its short axis onto/off of its own batter and along its long axis to cross under the low bar and over the berms. I'd probably go (non equilateral) kiwi.
I see no reason why that configuration would be illegal. Of course how you use it involves a different set of rules. |
For that team, they probably wouldn't have been drafted at all and now they are not only playing after lunch, their an alliance captain. That seems like an upgrade to my kids' St. Louis Experience. I don't know how I'd tell my kids no if they wanted to give it a shot. Dr. Joe J. |
#11
G22 ROBOTS may not pin an opponent’s ROBOT for more than five (5) seconds. A ROBOT will be considered pinned until the ROBOTS have separated by at least six (6) feet. The pinning ROBOT(s) must then wait for at least three (3) seconds before attempting to pin the same ROBOT again. Pinning is transitory through other objects. If the pinned ROBOT chases the pinning ROBOT upon retreat, the pinning ROBOT will not be penalized, and the pin will be considered complete. Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL. If extended and egregious, RED CARD There is no FIRST Robotics Competition specific definition of pin, so a general definition applies; “to prevent or stop something from moving.” As a result, contact is not required for pinning to occur. For example, a ROBOT parked right behind an opponent that is on the BATTER could be considered pinning because the dividers on the BATTER and the parked ROBOT prevent the opponent from moving. Generally, pins that exceed fifteen (15) seconds are considered extended and egregious, regardless of a pinning ROBOT’s mobility, however circumstances vary and the assesment is open to REFEREE discretion. Last edited by jdunston94 : 31-03-2016 at 11:29. |
#12
The intent isn't to draw penalties, but to keep the opponent in your courtyard so they cannot get back on their batter for the capture in time. I'd be surprised if G11 was called in that situation unless it was overly obvious that you went out of your way to contact them.
#13
IMHO, given the 20 second rule, that is a nuance that will be lost on most refs.
#14
I don't understand how this robot design and the strategy of stopping low goal scoring meets the definition of a Choke-hold.
A choke-hold strategy is one, when executed effectively, guarantees a win, regardless of what the opposition does. |
#15
You blocked points from goals but can't you still get points from sweeping and puppy guarding the secret passage?
