Go to Post Haters gonna hate; kill 'em with kindness. - Taylor [more]
Unread 30-03-2016, 14:36
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
FRC #2168 (Aluminum Falcons)
Team Role: Coach
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
Replacement Pinions for 15T 32DP Pinion from Andy Mark
Hello FRC Community,
Just wanted to share some potentially helpful information.
For our shooter gearbox we currently run two 775 pros into a custom gearbox using the 60T 32DP steel Andy Mark gear for our bull gear am-0927. For pinions we have been using the 15T 32DP steel pinions from Andy Mark am-0896. For anyone who recently has been looking to buy spares or maybe make a gearbox redesign you have learned that Andy Mark is out until late April. That being said I located a supplier who sells a high strength carbon steel replacement with the exact same specs minus the shaft hole diameter i.e., 15T, 32DP, 0.46875" pitch diameter (called the manufacturer to confirm this). The shaft hole is 5mm which is fine for 775 model motor as you need to drill to press fit on a 0.25" shaft.
Part #8615
http://www3.towerhobbies.com/cgi-bin...?&I=LXDZFA&P=7
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 30-03-2016, 14:38
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Replacement Pinions for 15T 32DP Pinion from Andy Mark
Isn't the 775PRO already a 5mm shaft?
Unread 30-03-2016, 14:47
lnex1357's Avatar
AKA: Joshua Miller
Team Role: Coach
Thumbs up Re: Replacement Pinions for 15T 32DP Pinion from Andy Mark
Correct! My mistake, we have been drilling the AM pinions to press on .196" or 5mm shaft. Was crossing the press fit dimensions of our output shaft on our gearbox to mate with gearbox pulley.
