Go to Post I don't fully buy into the 'we're all winners' concept. That is a broad statement that doesn't really say much. How did we become all winners? What did we do to become winners? Pay an expensive registration fee and participate in a robotic competition? - JaneYoung [more]
Unread 31-03-2016, 11:08
Golden_Tiger's Avatar
Golden_Tiger Golden_Tiger is offline
The Best
FRC #4284 (ScotBot)
Team Role: Mechanical
Rookie Year: 2015
Golden_Tiger is an unknown quantity at this point
Compressor not Receiving Voltage (Need quick help if possible, currently at regional)
Hello, we are currently having some issues with our compressor, as it is not receiving any voltage to it to turn on when we enable. We checked connections to it, the PCM is receiving voltage as it lights up green. The compressor worked fine two weeks ago at our last regional, but we are not entirely sure what the issue is. We are trying to get a new PCM to see if that is the issue, but we would like to receive any suggestions if there are any.
Thanks, this practice day has been a bit more stressful than desired.
Unread 31-03-2016, 11:09
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Compressor not Receiving Voltage (Need quick help if possible, currently at regio
If you stick a multimeter into the PCM compressor ports, do you see any voltage?
Is your pressure switch hooked up correctly?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 31-03-2016, 11:11
The Best
FRC #4284 (ScotBot)
Rookie Year: 2015
We do not see any voltage at all when using the multimeter, and the pressure switch is hooked up correctly. That's why we believe it may the PCM.
Anything helps though.
Unread 31-03-2016, 11:15
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Is the switch working? Try taking it out of the PCM, and stick 2 wires into the PCM pressure switch port. See if you get voltage coming out, and then short the 2 wires together, and see what the voltage is.
But it does sound like you have a dead PCM, if everything is plugged in correctly.
You do have it plugged into the CAN? And the Vin is plugged in correctly?
If you could post a picture, that might help people troubleshoot.
1771- Mentor (2015)
Unread 31-03-2016, 11:22
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Try shorting the pressure switch inputs, then see if you get any voltage on the compressor outputs while the robot is enabled. Best way to do this is to unplug both the compressor and switch, then use a short wire to bridge the two inputs for the switch.
Also check on the driver station that the PCM version number shows up - if that isn't there, then there's something wrong with the CAN bus or the switch.
If the version number is there and shorting it doesn't work, then there's probably something wrong with the PCM.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Arthur3103 Arthur3103 is offline
Mentor Team 3103
AKA: Arthur Purpich
FRC #3103 (Iron Plaid)
Rookie Year: 2010
Arthur3103 is an unknown quantity at this point
You need to prove that parts of the system are good. Start at either the PDB or start at the compressor. Test one component at a time and be methodical.
Check the wiring from the PDB to the PCM. Take out the wires and reinsert them in the PDB and PCM.
Take out the compressor wires and reinsert them.
Remove the PDB fuse and push it back in again. Perhaps change the PDB fuse to a spare.
Will the compressor run when given 12v from another source - do not connect to a tank if trying this. You want the compressed air exhausting to the atmosphere for safety.
If the compressor is good, test the pressure switch.
Good luck.
Unread 31-03-2016, 11:24
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
I'd also make sure that you have the PCM 12V input plugged into the PDP, not the VRM.
1771- Mentor (2015)
Unread 31-03-2016, 11:30
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Use the online tool. Click the self test button and see what it returns.
Also, you are at a regional surrounded by people that can help you much quicker. Find a csa ask a team everyone will help.
Unread 31-03-2016, 11:39
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Our team had an issue with our compressor earlier in the year, though I think it ended up actually being an issue with the code. Not sure of the specifics but might be something to look into.
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Make sure it's programmed properly. Maybe try disconnecting all tanks/hoses from the compressor and enabling. If it runs by itself like that, it's probably something like a pressure switch or PCM.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 31-03-2016, 13:19
The Best
FRC #4284 (ScotBot)
Rookie Year: 2015
I apologize for our long delay, we found that the pressure switch was the problem, and we are trying to fix it now.
Thanks to all for the suggestions. They are greatly appreciated.
Unread 31-03-2016, 13:32
The Best
FRC #4284 (ScotBot)
Rookie Year: 2015
We have found that our pressure switch is staying open regardless of pressure. We have a Nason SM-2B-115R/443, which is meant to stay closed normally, but open at 115 psi, and close again if the pressure drops below 95 psi. We do not know how to fix it at all, so if there is any suggestions that would fix this too that would be great.
Unread 31-03-2016, 13:36
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Go to spare parts and get another one, that is why they are there.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 31-03-2016, 13:44
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
No user serviceable parts. Only solution is to replace.
  #15   Spotlight this post!
Unread 31-03-2016, 15:11
Team Role: Student
Rookie Year: 2016
"No user serviceable parts"?! Well, we'll just see about that! That's never stopped me from disassembling and/or repairing something! *insert evil laugh here*
Note: if you do attempt to disassemble the pressure switch, don't try to use it again.
