Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 01-04-2016, 08:34
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
Exclamation Analog Pressure Sensor Labview Programming
We are trying to use the Analog Pressure sensor to display the pressure of the pneumatic system of the robot during the match. We are using LabVIEW robot code, and the sensor is plugged into the Analog Ports on the roboRIO. We used the AI Open.vi and the AI Get Value.VI in LabVIEW to retrieve the data. However, it is returning values between 398-402. How do we fix this issue and get the correct value from the sensor?
Thanks!
