Go to Post dont be afraid of new technology. embrace it and experment with it figure out the problems on the way and then tell us about it so it gets easier. - Tytus Gerrish [more]
Unread 01-04-2016, 15:00
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
Rope for a climber
I'm looking at using this rope for climbing. The rope says not for lifting, but is rated for 90lbs, would this be a problem? We would be using 4 strands, 4x90=360 so it would support 2.5 times our robot weight.
Unread 01-04-2016, 15:11
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Rope for a climber
This is the stuff you want.
Unread 01-04-2016, 16:19
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
ya we used 7/64th's Dynema cable. 1600 lb test and no stretch. very abrasion resistant.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 01-04-2016, 16:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Just be aware that Spectra and Dyneema are slipperier than "normal" ropes like nylon. Thoroughly strength test your knots to make sure the won't slip.
Unread 01-04-2016, 17:38
dkavanagh dkavanagh is offline
FRC #0578 (Red Raider Robotics)
Rookie Year: 2015
dkavanagh is an unknown quantity at this point
We used this:
http://www.amazon.com/Braided-diamet...C CV4PTRV7JJ5
It was quite sturdy and held up well.
We also used a 400lb test kevlar line that worked, but it frayed way too easily and couldn't be trusted.
Unread 01-04-2016, 19:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
The knot also dramatically reduces the working load of the line. There are certain knots that are better than others from this standpoint.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-04-2016, 07:15
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
The rule of thumb I've heard as a sailor is that in typical cordage applications knots will reduce available strength by about 50%.
There are many factors that will affect this result. The linked research on different knots, found that well tied knots of different varieties will reduce strength less than the rule of thumb. The paper didn't mention what the knots were tied to, but my guess is something round. If you attach cordage to a sharp edge, then your resulting system strength is likely to be much less. http://itrsonline.org/wordpress/wp-c...hards.2004.pdf
Also the cordage used in the above test is quite a bit different than spectra.
Also note that if you redirect the rope's direction with a carabiner, it is going to be under greater strain than it would be in a straight line application.
All in all, sand out sharp edges where your rope is attached or contacts a surface and use rope that is much stronger than what you think is needed.
Dave
Unread 01-04-2016, 19:13
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
I second the Spectra cord. It's great stuff. We are using the 2.5 mm diameter for climbing and 3 mm diameter to stop our catapult. Both were also purchased through Amazon.
As for the comment about the knots slipping, we haven't found that at all. We don't do any crazy complicated knots, and the cord holds the knots very well.
Unread 01-04-2016, 23:39
BetaHelix's Avatar
FRC #4646
What motors are you using for your climbers? Would 1-2 775pros work if we have a ratchet for support?
Unread 01-04-2016, 23:40
Cory's Avatar
AKA: Cory McBride
any motor is going to work if geared properly and given enough time. The amount of time you want to lift in is going to bound the problem for you.
2001-2004: Team 100
Unread 01-04-2016, 23:48
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
The Linear Motion tab, in the JVN calculator
http://www.chiefdelphi.com/media/papers/2755
Should help you find the necessary gear reduction, pulley size etc. As Cory stated it is all dependent on the amount of time you wish to take to climb.
As an example one 775pro in a 64:1 VP with a 1 inch diameter spool(not taking into account spool size increase as cord is winded) should be easily be able to lift a 140 pound robot in under 3 seconds
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 02-04-2016, 00:03
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You know, there's a couple of "advanced" topics you may want to research on your own time.
Static loading and dynamic loading. The 90 lb is likely a static load situation. Your 150 lb robot is most definitely a dynamic load situation.
Static: Not moving, no "extra" forces. (Just to pick an example, you park yourself on the end of a rope rated for your weight and very gently remove the support you're standing on.)
Dynamic: Motion involved, "extra" forces from various factors. (Going with the previous example, you jump up and grab onto the same rope--or use it to stop a fall, your choice. BTW, don't try this at home, I don't expect it'll end well.)
Long story short, something that's rated at 150 lb might not hold up when 150 lb is lifting itself--you might want 300 lb, 450 lb, even 600 lb. Maybe more. And 4 strands of 90-lb rope may in theory be 360 lb, but even the rig technique you use can drop that.
I could go more in-depth, but this has the makings of a) off-topic and b) fun offseason learning project. Talk to your (mechanical) engineering mentors about trying this sort of thing out or running the numbers.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
